Ultimate UHD Drives Flashing Guide Updated 2025
hexagon
#2686 Post by hexagon » Thu Feb 06, 2025 1:56 pm
Works like charm, thnx
zittrig
#2687 Post by zittrig » Thu Feb 06, 2025 6:01 pm
I've a BE16NU50 for a cousin in progress.
It have originaly the firmware BE16NU50 1.00 installed and it works OOTB with it.
My cousin want to use MakeMKV or DVDFab, first he want to test both of the tools. Has the original firmware the same quality like the WH16NS60 1.00?
Edit: Ok, speeding up is very low. Only 4.8x after 18 minutes...
trooperdadon87
#2688 Post by trooperdadon87 » Sat Feb 08, 2025 5:47 pm
MartyMcNuts wrote:
Tue Feb 04, 2025 6:41 am
trooperdadon87 wrote:
Mon Feb 03, 2025 8:59 pm
I'm new to the forum. I've been using Makemkv primarily for my Blu-rays to back them up to an external hard drive. It's always worked great so far.
However, I want to switch to 4k UHD soon and so my question is:
Is this generally possible with my BR drive "Techpulse 120" BD-XL M-Disc and 4K UHD is written on the front?
Do I have to flash this first? How do I go about this? Unfortunately, my English skills are a bit poor.
Thank you for your help and I hope I'm in the right post.
Greetings, trooper
Post your MakeMKV drive & Libredrive info.
Laufwerksinformation
OS-Gerätename: E:
Aktuelles Profil: DVD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.02
Serienummer: ...
Firmware-Datum: 2117-11-30 12:18
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
#2689 Post by MartyMcNuts » Sat Feb 08, 2025 8:55 pm
Greetings, trooper
OS-Gerätename: E:
Produzent: HL-DT-ST
Revision: 1.02
Serienummer: ...
Yes, it has to be flashed to enable libredrive as it is a requirement for UHD readability.
It's easy to do. Just follow the guide. Your drive is a LG BU40N. Flash it to BU40N 1.03-MK and you're all set.
dellsam34
#2690 Post by dellsam34 » Sun Feb 09, 2025 12:16 am
I got the LG WH16NS40 Flashed with WH16NS60 Firmware v1.02, very simple yet it performs at it should, Have done only few rips but I will report back if I find any issues with it, but so far so good.
trooperdadon87
#2691 Post by trooperdadon87 » Sun Feb 09, 2025 1:51 pm
OS-Gerätename: E:
Produzent: HL-DT-ST
Revision: 1.02
Serienummer: ...
where can i get the BU40N 1.03MK firmware ? do i have to download somewhere?
#2692 Post by Billycar11 » Sun Feb 09, 2025 2:29 pm
Did you even read post 1?
It's in there the all you need pack
trooperdadon87
#2693 Post by trooperdadon87 » Sun Feb 09, 2025 3:25 pm
for sure. i downloaded the all you need firmware pack and exracted the bu4on file.
now i have this with a .bin data
when i use the command how explaned there is coming:
Input file in raw format is required
DEBUG: Code 4280778757 at wfCw3OE9o6xoDD[;$ZOJdpeNgiQob2>_:29397978
Command produced error code 0xff278005
this is my command line:
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i: C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N
#2694 Post by Billycar11 » Sun Feb 09, 2025 3:35 pm
You left out the fw name... You only have the path but to nothing you also need file name see post 1 or use the GUI
trooperdadon87
#2695 Post by trooperdadon87 » Sun Feb 09, 2025 3:41 pm
like this?
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
now it says : Input file not found -- C:\Users\marcm\Downloads\The
Internal error 0x83000001
#2696 Post by d00zah » Sun Feb 09, 2025 3:47 pm
like this?
Use ' ' or " " around paths/filenames which include spaces.
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i 'C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin'
trooperdadon87
#2697 Post by trooperdadon87 » Sun Feb 09, 2025 3:56 pm
like this?
THANKS ! i think it was working.
Reading input file C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_211711301218_KZBIASC0500
100% Operation finished
Done successfully
what else do i have to do? fixing some bugs next (sleeping bug) or everything working now?
when i check now and open makemkv there is still 1.02 , why?
can someone help me? was it working or still 1.02 ? i dont know why there shows still 1.02 when i open makemkv ?
here is the information:
Last edited by trooperdadon87 on Sat Feb 15, 2025 4:13 pm, edited 1 time in total.
trooperdadon87
#2698 Post by trooperdadon87 » Sun Feb 09, 2025 4:08 pm
uhdarty
#2699 Post by uhdarty » Mon Feb 10, 2025 8:26 pm
Bought an LG BH16NS40, FW 1.05, SVC CODE NS51, manufacturing date 2024 October
Now I cannot find this drive in post#1 exactly but reading viewtopic.php?t=25901
I see user had success with flashing HL-DT-ST-BD-RE_BH16NS40-NS50-1.03-NM00000-211711201943.bin
1 - can I somehow backup the current FW which I can restore in case of issues? or restore is not fully possible?
2 - since that success story is from 2022 perhaps my current 1.05 is a different 1.05, also my drive is a different BH16NS40, possible?
3 - thank you :)
zittrig
#2700 Post by zittrig » Mon Feb 10, 2025 8:35 pm
Show your MakeMKV drive information.
But I think you can flash directly to WH16NS60 1.02MK.
Edit:
Sorry I've read your model wrong. Of course is the BH16NS40 with NS51 flashable.
You don't need a firmware backup. With the original LG firmware auto updater you can get your drive back to 1.05.
