MKV file reported to be copy protected with latest version
rikkards
Normally when I backup a Blu-Ray I will usually back it up using makemkvcon and then drop the size to something more reasonable using handbrake. Since I upgraded to 1.16 I get the error message in handbrake saying no titles found. Your source may be copy protected, corrupt, badly mastered or in a format which handbrake doesn't support. Normally I would be looking at handbrake but since nothing has changed except my makemkvcon version, that is why I am starting here. Any ideas where to start?
- Contact:
Re: MKV file reported to be copy protected with latest versi
please post mediainfo output for MKV file.
rikkards
Here you go. Cool tool.
EDIT: I just realized I haven't upgraded to 16. I may try it again with the latest one then.
General
Unique ID : 76014070976782010479366727749512857342 (0x392FC70D71C7DDBBEC0BAC42AB5A06FE)
Complete name : D:\Temp\title00.mkv
Format : Matroska
Format version : Version 2
File size : 35.0 GiB
Duration : 2h 25mn
Overall bit rate mode : Variable
Overall bit rate : 34.4 Mbps
Encoded date : UTC 2011-11-03 19:34:28
Writing application : MakeMKV v1.6.15 linux(x86-release)
Writing library : libmakemkv v1.6.15 (1.2.0/1.1.0) i486-linux-gnu
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 25mn
Bit rate mode : Variable
Bit rate : 24.1 Mbps
Maximum bit rate : 32.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.484
Stream size : 24.5 GiB (70%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 1 597 Kbps / 1 510 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : Lossless
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.53 GiB (4%)
Title : 3/2+1
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 224 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 233 MiB (1%)
Title : 2/0
Language : English
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 466 MiB (1%)
Title : 3/2+1
Language : Spanish
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Portuguese
Default : No
Forced : No
Audio #6
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Stream size : 785 MiB (2%)
Title : 3/2+1
Language : French
Default : No
Forced : No
Audio #7
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : German
Default : No
Forced : No
Audio #8
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Italian
Default : No
Forced : No
Audio #9
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Japanese
Default : No
Forced : No
Audio #10
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Russian
Default : No
Forced : No
Audio #11
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Spanish
Default : No
Forced : No
Audio #12
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 224 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Czech
Default : No
Forced : No
Audio #13
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Polish
Default : No
Forced : No
Audio #14
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 224 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Thai
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : Japanese
Default : Yes
Forced : No
Text #2
Format : PGS
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #4
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #5
Format : PGS
Default : No
Forced : No
Text #6
Format : PGS
Default : No
Forced : No
Text #7
Format : PGS
Language : Danish
Default : No
Forced : No
Text #8
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #9
Format : PGS
Language : French
Default : No
Forced : No
Text #10
Format : PGS
Language : German
Default : No
Forced : No
Text #11
Format : PGS
Language : German
Default : No
Forced : No
Text #12
Format : PGS
Language : Italian
Default : No
Forced : No
Text #13
Format : PGS
Language : Italian
Default : No
Forced : No
Text #14
Format : PGS
Language : Dutch
Default : No
Forced : No
Text #15
Format : PGS
Language : Norwegian
Default : No
Forced : No
Text #16
Format : PGS
Language : Russian
Default : No
Forced : No
Text #17
Format : PGS
Language : Russian
Default : No
Forced : No
Text #18
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #19
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #20
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #21
Format : PGS
Language : Czech
Default : No
Forced : No
Text #22
Format : PGS
Language : Czech
Default : No
Forced : No
Text #23
Format : PGS
Language : Greek
Default : No
Forced : No
Text #24
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #25
Format : PGS
Language : Hebrew
Default : No
Forced : No
Text #26
Format : PGS
Language : Polish
Default : No
Forced : No
Text #27
Format : PGS
Default : No
Forced : No
Text #28
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #29
Format : PGS
Language : Thai
Default : No
Forced : No
Text #30
Format : PGS
Language : Thai
Default : No
Forced : No
Text #31
Format : PGS
Language : Turkish
Default : No
Forced : No
Text #32
Format : PGS
Language : French
Default : No
Forced : No
Text #33
Format : PGS
Language : French
Default : No
Forced : No
Text #34
Format : PGS
Language : Japanese
Default : No
Forced : No
Text #35
Format : PGS
Language : English
Default : No
Forced : No
Text #36
Format : PGS
Language : French
Default : No
Forced : No
Text #37
Format : PGS
Language : German
Default : No
Forced : No
Text #38
Format : PGS
Language : Italian
Default : No
Forced : No
Text #39
Format : PGS
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 00
00:18:34.321 : en:Chapter 01
00:22:26.470 : en:Chapter 02
General
Format : Matroska
Duration : 2h 25mn
Video
Format : AVC
Duration : 2h 25mn
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit depth : 24 bits
Title : Lossless
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit depth : 24 bits
Title : 3/2+1
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 224 Kbps
Bit depth : 16 bits
Title : 2/0
Language : English
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Spanish
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Default : No
Forced : No
Audio #6
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : French
Default : No
Forced : No
Audio #7
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : German
Default : No
Forced : No
Audio #8
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Italian
Default : No
Forced : No
Audio #9
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Japanese
Default : No
Forced : No
Audio #10
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Russian
Default : No
Forced : No
Audio #11
Format : DTS
Codec ID : A_DTS
Duration : 2h 25mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Spanish
Default : No
Forced : No
Audio #12
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 224 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Czech
Default : No
Forced : No
Audio #13
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Polish
Default : No
Forced : No
Audio #14
Format : AC-3
Codec ID : A_AC3
Duration : 2h 25mn
Bit rate : 224 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Thai
Default : No
Forced : No
Text #1
Format : PGS
Language : Japanese
Default : Yes
Forced : No
Text #2
Format : PGS
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #4
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #5
Format : PGS
Default : No
Forced : No
Text #6
Format : PGS
Default : No
Forced : No
Text #7
Format : PGS
Language : Danish
Default : No
Forced : No
Text #8
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #9
Format : PGS
Language : French
Default : No
Forced : No
Text #10
Format : PGS
Language : German
Default : No
Forced : No
Text #11
Format : PGS
Language : German
Default : No
Forced : No
Text #12
Format : PGS
Language : Italian
Default : No
Forced : No
Text #13
Format : PGS
Language : Italian
Default : No
Forced : No
Text #14
Format : PGS
Language : Dutch
Default : No
Forced : No
Text #15
Format : PGS
Default : No
Forced : No
Text #16
Format : PGS
Language : Russian
Default : No
Forced : No
Text #17
Format : PGS
Language : Russian
Default : No
Forced : No
Text #18
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #19
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #20
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #21
Format : PGS
Language : Czech
Default : No
Forced : No
Text #22
Format : PGS
Language : Czech
Default : No
Forced : No
Text #23
Format : PGS
Language : Greek
Default : No
Forced : No
Text #24
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #25
Format : PGS
Language : Hebrew
Default : No
Forced : No
Text #26
Format : PGS
Language : Polish
Default : No
Forced : No
Text #27
Format : PGS
Default : No
Forced : No
Text #28
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #29
Format : PGS
Language : Thai
Default : No
Forced : No
Text #30
Format : PGS
Language : Thai
Default : No
Forced : No
Text #31
Format : PGS
Language : Turkish
Default : No
Forced : No
Text #32
Format : PGS
Language : French
Default : No
Forced : No
Text #33
Format : PGS
Language : French
Default : No
Forced : No
Text #34
Format : PGS
Language : Japanese
Default : No
Forced : No
Text #35
Format : PGS
Language : English
Default : No
Forced : No
Text #36
Format : PGS
Language : French
Default : No
Forced : No
Text #37
Format : PGS
Language : German
Default : No
Forced : No
Text #38
Format : PGS
Language : Italian
Default : No
Forced : No
Text #39
Format : PGS
Language : Spanish
Default : No
Forced : No
Menu
rikkards
Well I upgraded to 1.16 and didn't get the same message. Although I didn't use the same Blu-Ray as I lent it to a buddy. I will need to get it back and try again. Otherwise I assume it is all good.
rikkards
I did try running the existing MKV through 1.16 to see if it would fix the file but it didn't I may see if there is a newer version of Handbrake to see if it actually an issue with it.
