trooperdadon87
Post by trooperdadon87 »
MartyMcNuts wrote:
Tue Feb 04, 2025 6:41 am
trooperdadon87 wrote:
Mon Feb 03, 2025 8:59 pm
I'm new to the forum. I've been using Makemkv primarily for my Blu-rays to back them up to an external hard drive. It's always worked great so far.
However, I want to switch to 4k UHD soon and so my question is:
Is this generally possible with my BR drive "Techpulse 120" BD-XL M-Disc and 4K UHD is written on the front?
Do I have to flash this first? How do I go about this? Unfortunately, my English skills are a bit poor.
Thank you for your help and I hope I'm in the right post.
Greetings, trooper
Post your MakeMKV drive & Libredrive info.
Laufwerksinformation
OS-Gerätename: E:
Aktuelles Profil: DVD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.02
Serienummer: ...
Firmware-Datum: 2117-11-30 12:18
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Sat Feb 08, 2025 5:47 pm
Greetings, trooper
OS-Gerätename: E:
Produzent: HL-DT-ST
Revision: 1.02
Serienummer: ...
Yes, it has to be flashed to enable libredrive as it is a requirement for UHD readability.
It's easy to do. Just follow the guide. Your drive is a LG BU40N. Flash it to BU40N 1.03-MK and you're all set.
dellsam34
Post by dellsam34 »
I got the LG WH16NS40 Flashed with WH16NS60 Firmware v1.02, very simple yet it performs at it should, Have done only few rips but I will report back if I find any issues with it, but so far so good.
trooperdadon87
MartyMcNuts wrote:
Sat Feb 08, 2025 8:55 pm
OS-Gerätename: E:
Produzent: HL-DT-ST
Revision: 1.02
Serienummer: ...
where can i get the BU40N 1.03MK firmware ? do i have to download somewhere?
Sun Feb 09, 2025 1:51 pm
Did you even read post 1?
It's in there the all you need pack
trooperdadon87
Billycar11 wrote:
Sun Feb 09, 2025 2:29 pm
for sure. i downloaded the all you need firmware pack and exracted the bu4on file.
now i have this with a .bin data
when i use the command how explaned there is coming:
Input file in raw format is required
DEBUG: Code 4280778757 at wfCw3OE9o6xoDD[;$ZOJdpeNgiQob2>_:29397978
Command produced error code 0xff278005
this is my command line:
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i: C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N
Sun Feb 09, 2025 3:25 pm
You left out the fw name... You only have the path but to nothing you also need file name see post 1 or use the GUI
trooperdadon87
Billycar11 wrote:
Sun Feb 09, 2025 3:35 pm
like this?
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
now it says : Input file not found -- C:\Users\marcm\Downloads\The
Internal error 0x83000001
Post by d00zah »
Sun Feb 09, 2025 3:41 pm
like this?
Use ' ' or " " around paths/filenames which include spaces.
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i 'C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin'
trooperdadon87
d00zah wrote:
Sun Feb 09, 2025 3:47 pm
like this?
THANKS ! i think it was working.
Reading input file C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_211711301218_KZBIASC0500
100% Operation finished
Done successfully
what else do i have to do? fixing some bugs next (sleeping bug) or everything working now?
when i check now and open makemkv there is still 1.02 , why?
can someone help me? was it working or still 1.02 ? i dont know why there shows still 1.02 when i open makemkv ?
here is the information:
Last edited by trooperdadon87 on Sat Feb 15, 2025 4:13 pm, edited 1 time in total.
trooperdadon87
uhdarty
Post by uhdarty »
Bought an LG BH16NS40, FW 1.05, SVC CODE NS51, manufacturing date 2024 October
Now I cannot find this drive in post#1 exactly but reading viewtopic.php?t=25901
I see user had success with flashing HL-DT-ST-BD-RE_BH16NS40-NS50-1.03-NM00000-211711201943.bin
1 - can I somehow backup the current FW which I can restore in case of issues? or restore is not fully possible?
2 - since that success story is from 2022 perhaps my current 1.05 is a different 1.05, also my drive is a different BH16NS40, possible?
3 - thank you :)
zittrig
Post by zittrig »
Show your MakeMKV drive information.
But I think you can flash directly to WH16NS60 1.02MK.
Edit:
Sorry I've read your model wrong. Of course is the BH16NS40 with NS51 flashable.
You don't need a firmware backup. With the original LG firmware auto updater you can get your drive back to 1.05.
redmarple
Post by redmarple »
Should I flash it to 3.10 MK?
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Serial number: [redacted]
Firmware date: 2117-03-31 14:26
Bus encryption flags: 1F
Firmware version: 3.01
zittrig
Post by zittrig »
3.10MK (with sleep bug) or WH16NS60 1.02MK (without sleep bug).
