Burning 3D blu-ray from MKV
rnranimal
Post by rnranimal » Sat Feb 08, 2025 12:59 am
So I took the Jaws 3 UHD set and pulled the 7.1 audio from the UHD and synced it to the 3D blu-ray, combining my favorite audio and visual options. I am able to play this file via USB on my Sony BR player after processing with tsmuxer and moving the video streams into proper order and saving as m2ts. However, for some reason, I can not rewind and fast forward any of these 3D files I create. It freezes the player to try. If anyone has any idea about that, I'd love to hear some things to try. I've tried about every option in tsmuxer. So I would like to use tsmuxer to create a blu-ray of the MKV with my new audio and then burn that with Toast. I'm hoping this disc will function properly. But will this work to maintain 3D? Does the order of the two video streams still need switched like when creating a file to watch?
rnranimal
Re: Burning 3D blu-ray from MKV
Post by rnranimal » Sat Feb 08, 2025 5:34 pm
I went ahead and attempted it with the MVC moved into the 2nd position like I do when playing back from the file and it burned and plays correctly. I don't know that it need the position switch to work but it does. I can also skip chapters and rw/ff without issues.
