#2671 Post by Coopervid » Sun Feb 02, 2025 8:55 pm
trooperdadon87 wrote:
Sun Feb 02, 2025 6:46 pm
Hallo,
ich bin neu hier im Forum. Nutze bisher Makemkv v.a. für meine Blurays um diese zusätzliche auf eine externe Festplatte zu sichern. Hat bisher auch immer wunderbar funktioniert.
Ich möchte allerdings zeitnah auf 4k UHD umsteigen und daher meine Frage:
Geht dies grundsätzlich mit meinem BR-Laufwerk "Techpulse 120" BD-XL M-Disc und 4K UHD steht vorne drauf?
Muss ich dies zuerst flashen? Wie gehe ich hier vor? Meine Englisch Kenntnisse sind leider etwas dürftig.
Vielen Dank für eure Hilfe und hoffentlich bin ich im richtigen Beitrag.
Grüße trooper
Google Translate wrote: I'm new to the forum. I've been using Makemkv primarily for my Blu-rays to back them up to an external hard drive. It's always worked great so far.
However, I want to switch to 4k UHD soon and so my question is:
Is this generally possible with my BR drive "Techpulse 120" BD-XL M-Disc and 4K UHD is written on the front?
Do I have to flash this first? How do I go about this? Unfortunately, my English skills are a bit poor.
Thank you for your help and I hope I'm in the right post.
Greetings, trooper
Post the Makemkv info. This forum is English only!
rlentz2024
#2672 Post by rlentz2024 » Mon Feb 03, 2025 1:11 am
The flasher tool kept giving me errors so I went to the command line. I can't find the original dump i did of the drive. I think the laser may have started to fail. Can I use the recovery from another of the exact drive? Want to sent in to have warrantied.
#2673 Post by Billycar11 » Mon Feb 03, 2025 2:25 am
just use the official LG updater dont think lg checks anyway
redmarple
#2674 Post by redmarple » Mon Feb 03, 2025 3:49 pm
I found a local facebook marketplace seller who is willing to sell me a BDR-209D for cheap. I take a look before I buy to verify the firmware version/date. @coopervid may I also get a PM with the flasher? I once flashed a UD-03 successfully.
trooperdadon87
#2675 Post by trooperdadon87 » Mon Feb 03, 2025 8:59 pm
Greetings, trooper
indigo9
#2676 Post by indigo9 » Tue Feb 04, 2025 1:50 am
Thanks for the guides. I purchased an LG WH16NS40 and was able to flash it with ease.
knotReuben
#2677 Post by knotReuben » Tue Feb 04, 2025 3:34 am
Want to say thanks for these tools. I followed the guide in the first post for macOS. I have a Verbatim 43888 that came with the v1.05 firmware code. Using the guide I used the encrypted command to flash the v1.03 firmware. Now I'm off to the races! Thanks again for all the folks working on these programs, firmware, guides, and video. It's appreciated!
#2678 Post by MartyMcNuts » Tue Feb 04, 2025 6:41 am
Greetings, trooper
Post your MakeMKV drive & Libredrive info.
spamtom
#2679 Post by spamtom » Tue Feb 04, 2025 8:40 pm
MartyMcNuts wrote:
Sun Jan 26, 2025 11:29 pm
spamtom wrote:
Sun Jan 26, 2025 3:33 pm
Hi, new to this so appologies. Having read most of the guides and the firs5 post i am still missing some basics and want to check what i think is correct. If i purchased a new BDR-XS07TUHD from Amazon this will not work with makemkv as the firmware is going to be unpatchable. Instead I need to find one for sale that’s older. Do these drives ever get patched as in are people working on patching them/finding exploits? Do any new external drives work straight off the shelf
No new Pioneer external drives work for UHD at all. They all have post 11/2022 unpatchable firmware. This has been worked on for 2+ years now without success. It's not looking good.
The only external drive that still currently works OOTB is the Verbatim 43888 (Pioneer BDR-UD04 version). The Verbatim 43888 (LG BU40N version can be flashed).
Thanks MartyMcNuts, purchased the 43888 on amazon and makemkv reports unpatched drive. However now it appears the new hobbit AUJ UHD won't rip as volume key unknown. Added public keydb file no joy, assume I just need to submit that file to get the key added?
#2680 Post by MartyMcNuts » Tue Feb 04, 2025 10:36 pm
If this is a new release disc then yeah, possibly. If it's been out for a couple of months, it may be something else.
Ensure MakeMKV has internet access as it needs to download the hashed keys database for UHD discs.
Also, do you see any mention in the log window about "HK download failed"?? Often, the download is blocked as the server is based in Russia. You may have to run MakeMKV through a VPN.
spamtom
#2681 Post by spamtom » Wed Feb 05, 2025 12:23 pm
Slightly nervous about having an app making and pulling files from a Russian server as obv there is a reputation associated with servers hosted in certain country’s which is why I went with pulling a public keydb file myself manually and vetting the file. Would prefer to do that each time. I followed a guide on here on how to add the keydb file I assume that’s still supported option. Any ideas on how you submit to the public keydb file? Cheers
Mr_Orange
#2682 Post by Mr_Orange » Wed Feb 05, 2025 12:31 pm
We have all been using MakeMKV's SDF file for years without any issues, no matter where it has been hosted. Do you really think the software would be so widely used if it was routinely infecting people's computers?
Each to their own though. Grab the dump file that MakeMKV creates, send it to the relevant MakeMKV email address and create a post with the details of the film and the dump file. You can also attach the dump file to the post and one of the folks who help maintain the public KeyDB will grab it and add the key.
spamtom
#2683 Post by spamtom » Thu Feb 06, 2025 12:40 am
It's great that MakeMKV and its SDF download has been reliable for many years. However, relying solely on past experience or wide availability are not foolproof cybersecurity strategies (In fact the greater install base the more attractive it is to bad actors). Threats, such as supply chain attacks, are becoming more common and sophisticated, posing risks to even well-regarded software. Unfortunately, servers and communications originating from certain regions can also present higher risks of these attacks.
Perhaps my background in secops has heightened my awareness of these risks, but it doesn't hurt to stay vigilant and proactive in protecting yourself. A good example is Notepad++, where the update process was hijacked to distribute malicious installers of the StrongPity malware. Similarly, there are numerous documented cases of supply chain attacks in GitHub repositories. The Notepad++ and most of the GitHub supply chain attacks didn't involve the creators or maintainers of the software, so trusting them and their past work would have provided false reassurance in those cases.
For my own use, I prefer the zero trust strategy, anything that’s been downloaded from the internet gets throughly vetted first before using them, no auto updates etc. If others prefer automatic updates and are comfortable doing that, that's their choice. However, I don't mind the small inconvenience of manually obtaining files from time to time and doing my own checks—after all, better safe than sorry.
I appreciate your advice on sending the dump to the email. Cheers!
hexagon
#2684 Post by hexagon » Thu Feb 06, 2025 1:56 pm
Works like charm, thnx
zittrig
#2685 Post by zittrig » Thu Feb 06, 2025 6:01 pm
I've a BE16NU50 for a cousin in progress.
It have originaly the firmware BE16NU50 1.00 installed and it works OOTB with it.
My cousin want to use MakeMKV or DVDFab, first he want to test both of the tools. Has the original firmware the same quality like the WH16NS60 1.00?
Edit: Ok, speeding up is very low. Only 4.8x after 18 minutes...
