Enabling LibreDrive on new ASUS BW-16D1HT v3.11
Hi
I just purchased a new ASUS BW-16D1HT and installed it yesterday. It has firmware 3.11 from the factory, here are the details from MakeMKV:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KL5O15B4942
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 76
I want to enable LibreDrive. I did a bit of research here and it seems I need to re-flash the drive using the SDFtool Flasher 1.3.5. I also downloaded Marty's firmware pack and found version 3.10 MK file in it for this drive. Is this the version I should use, or is there a 3.11 MK version available? Does it matter?
Obviously I don't want to bork my new drive.
I'm on Windows 11 if it matters, latest 23H2 build. I plan to use Handbrake to encode for playback through Kodi.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Re: Enabling LibreDrive on new ASUS BW-16D1HT v3.11
see guide below has the answers you need
Thanks, successfully flashed my drive with the 3.10 MK version.
Just to let everyone know, the procedure is quite easy. Just go ahead
CaptainPed
Hi
Info
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ...
Highest AACS version: 77
I want to enable LibreDrive. I did a bit of research here and it seems I need to re-flash the drive using the SDFtool Flasher 1.3.5. I also downloaded Marty's firmware pack and found version 3.10 MK file in it for this drive. I try to enable by clip in youtube. https://www.youtube.com/watch?v=Jho_lc7OS9Y It does not success. An error occurred as shown in the image.
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Startindex cannot be larger than length of string. (Parameter ‘starindex’).
Details
System.ArgumentOutOfRangeException: startIndex cannot be larger than length of string. (Parameter 'startIndex')
at System.String.Substring(Int32 startIndex, Int32 length
at System.String.Substring(Int32 startIndex)
at SDFtool_Flasher_Updated.Form1.comboBox_SelectFirmware_Click(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam
I would like to request guidance form experts to correct the errors so that the firmware can successfully updated. I’m on Windows 11 Pro 24H2 build.
Info
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ...
Details
Ensure you have MakeMKV installed in the default location.CaptainPed wrote: Sat Feb 08, 2025 3:12 pm Hi
Info
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ...
Details
Ensure there is no disc in the drive and the tray is closed.
The drive should have encrypted firmware so in SDFtool Flasher v1.3.5 you should see a green tick beside both "Drive Platform" and "Encrypted Firmware". If not, click the red X to toggle it to a green tick.
CaptainPed
Thank you very much for your advice. I followed it, but the error message still appears.
(Same error notification message as before) What should I do next?
Thank!
Thank!
How is the drive connected to your PC?CaptainPed wrote: Sun Feb 09, 2025 3:06 am Thank you very much for your advice. I followed it, but the error message still appears.
Thank!
CaptainPed
Internal connected in pc.
Show a screenshot of SDFtool Flasher when you have selected your drive and firmware.
I really can't tell why it isn't working for you. You may have to use the MakeMKV commandline to get it done.
CaptainPed
Good news I install new Windos 11, then run SDFtool again. It works. Thank you very much.MartyMcNuts wrote: Sun Feb 09, 2025 6:19 amShow a screenshot of SDFtool Flasher when you have selected your drive and firmware.
It has been a LONG time since I was on here, and needed to flash a new drive, thanks for the information. It worked, now I'm ripping 4K on a new drive again.
