(G)I-DLE [iDOL] IN SEOUL Blu-ray Failed to open disc
Gotopk
Post by Gotopk » Thu Feb 06, 2025 12:03 pm
I am new to ripping Blue ray disc but I watched a lot of youtube video.
I picked up a cheap combo from Cash Converters where it include OWC Mercury Pro 5.25 Inch External Optical Drive Enclosure and lg blue ray external drive for 150aud.
I believe the previous owner used this to rip blue ray.
my Firmware is solid, i didnt even need to update it .
However, when i tried to rip the latest Kpop concert for g idle it failed. My Christopher nolan collection is still arriving at the moment so i dont have any other disc to test.
The disc did open in my windows manual but the drive is disconnected when i try to double click on the content.
I believe it is the protection on the disc :/
Here is the error that i got from trying to open the disc
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZJ7381920' at offset '23078369280'
udf: node fe/efe failed!
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZJ7381920' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZJ7381920' at offset '32768'
Backup failed
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: ...
Highest AACS version: 81
Firmware version: 1.02
Re: (G)I-DLE [iDOL] IN SEOUL Blu-ray Failed to open disc
Post by dcoke22 » Fri Feb 14, 2025 7:08 pm
That error is a strange error for a drive in an OWC Mercury Pro enclosure. I would guess that the drive isn't getting enough power, but the OWC should be powered by its own external power supply.
It is possible, I suppose, that the power supply is weaker than it is supposed to be or is incorrect for the enclosure.
