It's not publicly available for good reason. Contact Billycar11 and pay for it.christopher_2 wrote: Tue Feb 04, 2025 11:49 pm How did you guys get this drive flashed, I bought one and am trying to figure it out SDF Tool doesn't have pioneer firmware in it.
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ...
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 12
Firmware version: ID06
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
Hello @Coopervid. I got a BDR 212V as well. Can you help me flash this drive:
Informations lecteur
Nom du lecteur SE : F:
Fabricant : PIONEER
Produit : BD-RW BDR-212V
Révision : 1.02
Numéro de série : ----
Date micrologiciel : 2022-05-31
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 81
Thank you
Fabricant : PIONEER
Révision : 1.02
Thank you
elCheapoDeluxe
Apparently I posted this in the OTHER BDR 212V thread under LibreDrive, instead of under UHD. This thread seems more active. Could I get the process for this update please? Thanks.
Revision: 1.02
Serial number: ...
Highest AACS version: 81
feel free to email that info to me see belowelCheapoDeluxe wrote: Wed Feb 05, 2025 5:40 pm Apparently I posted this in the OTHER BDR 212V thread under LibreDrive, instead of under UHD. This thread seems more active. Could I get the process for this update please? Thanks.
Revision: 1.02
Serial number: ...
Hello @Coopervid or Billycar11,
Wonder if you cold help me with my Pioneer 212V
OS device name: F:
Revision: 1.02
Serial number: xxxxxxxxxx
Thanks. It looks like it was manufactured in March 2024 (I got it today from Amazon), but firmware is from 2022.
OS device name: F:
Revision: 1.02
Thanks to Billycar11 for the help with my drive. Got it flashed over and working great!
I also had just received a BDR-212V and would like to flash it for UHD:
OS device name: /dev/sr0
Revision: 1.02
Serial number: ...
Firmware version: ID06Re: BDR 212V UHD Guide
georgek - find a post by Billycar11, his email is in his signature. That's what I did.georgek wrote: Sat Feb 22, 2025 8:36 pm I also had just received a BDR-212V and would like to flash it for UHD:Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: ... Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
I've obtained the flasher and firmware from a moderator on another forum...pharmer wrote: Sun Feb 23, 2025 1:06 am georgek - find a post by Billycar11, his email is in his signature. That's what I did.
Just received my BDR-212V today and would like to flash it to be able to do UHD.
Thanks.
Revision: 1.02
Serial number: XXXXXXXXXXXX
Thanks.
Revision: 1.02
PM is coming.SumGuy wrote: Wed Feb 26, 2025 9:54 pm Just received my BDR-212V today and would like to flash it to be able to do UHD.
Thanks.
Revision: 1.02
Just got my BDR-212V, looking to flash for UHD playing/ripping. Thanks in advance!
OS device name: E:
Revision: 1.02
Serial number: [redacted]
OS device name: E:
Revision: 1.02
PM sent.dnsrs wrote: Thu Feb 27, 2025 8:30 pm Just got my BDR-212V, looking to flash for UHD playing/ripping. Thanks in advance!
OS device name: E:
Revision: 1.02
Here's another new owner of a BDR-212V. This is what MakeMKV says:
Revision: 1.02
Serial number:
Highest AACS version: 21
I hope you can help me flash it to make it UHD friendly
Thank you!
Revision: 1.02
Serial number:
Thank you!
PM sent.Rudyard wrote: Sun Mar 02, 2025 12:27 am Here's another new owner of a BDR-212V. This is what MakeMKV says:
Revision: 1.02
Serial number:
I hope you can help me flash it to make it UHD friendly![]()
Thank you!
