To quote from:
http://en.wikipedia.org/wiki/Ripping
"Ripping is the process of copying audio or video content to a hard disk, typically from removable media.
The word is used to refer to all forms of media.
[Despite the name, neither the media nor the data is damaged after extraction.]"
To quote from:
http://en.wikipedia.org/wiki/Transcode
"Transcoding is the direct digital-to-digital data conversion of one encoding to another,[1]
such as for movie data files or audio files."
See:
http://en.wikipedia.org/wiki/DVD_ripper
[This is EXACTLY what MakeMKV is!]
Based on these definitions, I'm hoping we can all come to agreement, that 'MakeMKV' is
NOT a transcoding tool.
My reading of all this boils down the word 'transcode'
to mean, literally, to CHANGE codecs. ('trans' == change' and 'code' == codecs or encodings.
Wikipedia elsewhere discusses both .mkv and .mp4 file-extensions, and (correctly in my view)
refers to them as 'container-formats'. http://en.wikipedia.org/wiki/Container_format_(digital)
I mention all this here, because when I read how your product describes itself on
the base-page on the Internet, it totally MIS-states it! To quote from:
http://www.makemkv.com/
MakeMKV is your one-click solution to convert video that you own into free and
patents-unencumbered format that can be played everywhere.
MakeMKV is a format converter, otherwise called "transcoder".
I'd argue that rather than calling it a 'format converter', a better description would be to
call it a 'container-format converter'. And, that you DEFINITELY need to REMOVE
the phrase '...otherwise called "transcoder" '.
Because it is NOT a transcoder.
(Whether you should instead add the term 'ripper', is your call. According to the
strict defn, I guess makeMKV IS a 'ripping tool'. But, I'll let you decide about that point.)
Also, in another thread, we already discussed and concluded that 'makeMKV' is NOT
a compression-tool. Maybe something about that issue, should also get mentioned
in that product-description paragraph!?
[As an aside: another nice product, named 'HandBrake' is just the opposite of 'MakeMKV'.
HandBrake really IS a transcoder, and is designed to convert the video/audio sub-streams from
one codec type to another. That type of conversion takes MUCH more time and processing-power,
than doing what 'makeMKV' does. One of HandBrake's other nice features, is that it allows one to choose
whether to create the output-file as either a 'MP4' container or as a 'MKV' container.]
This is what I love about 'makeMKV'! MakeMKV is fast! Since it doesn't NEED to
change codec encodings, it can neatly and quickly extract the video and audio data
into a series of of 'mkv-containers'.
Nice job. Nice product!
Bottom line, I think your product description needs to be re-written. Someone with a bit
more technical understanding needs to carefully add terms such 'codec' and 'container-format',
to get the product description more in line with proper terminology.
[But, that's just my opinion.]
Thanks for listening. Hope this is helpful...
MakeMKV is NOT a transcoding-tool. Agreed???
- Contact:
H.264 codec and Veetle.com are very cool.
[And, so is MKV container-format.]
Re: MakeMKV is NOT a transcoding-tool. Agreed???
I'm not completely agree but your post is very close to be exactlySarasotaSlim wrote:To quote from:
To quote from:
Based on those definitions, I'm hoping we can all come to agreement, that 'MakeMKV' is
I think that GuinpinSoft company mean to convert your physical media and not you video into a media file that can be play everywhere...
I think this reading this:
It converts the video clips from proprietary (and usually encrypted) disc into a set of MKV files, preserving most information but not changing it in any way
So for any convert word, i think is relative to "video disk" into a media file without change video in any way....
in description makemkv's page, any use of conversion is about media disk into media file
please someone from GuinpinSoft, maybe marketing staff, can help us
By away, i like makemkv as well i like handbrake.....
I will leave handbrake when makemkv will compress video.
By
Marco
ps. sorry for my english hope ou understand my message
I agree 100% with the original poster. "Transcode" is mis-used in the main home page of makemkv. In fact, the main reason I came to the forum was to find out if makemkv was actually transcoding or just ripping/decrypting, as I do NOT want to transcode the data, I want a ripper. I want the original, pristine, un-re-encoded, bits from my blu-ray disc, stored in an easy to access and play file format.
It sounds like makemkv is what I want, but the author's use of the term "transcode" made me think otherwise.
If you want to transcode your blu-ray rips (e.g. to save hdd/server space, or to play them on lesser hardware like a smartphone or tablet), you need something like Handbrake, or meGUI.
Wouldn't it just be better to just PM Mike and mention that he should change the terminology on the MakeMKV website based on those reasons?
SC
SC
- Contact:
Hey, if you're on a 'personal name' (PM) basis with someone to 'lobby' on this issue,Smithcraft wrote:Wouldn't it just be better to just PM Mike and mention that he should change the terminology on the MakeMKV website based on those reasons?
SC
then by all means DO THAT.
We're just (somewhat knowledgeable) NEWBIES to this product, so we don't know
the managers/developers.
I don't think it matters what kind of relationship I have with the developers ( and I don't have one other than being a user ), the content of this message, IMO, is more relevant to being a PM than a forum post.
Personal Message doesn't mean that I have to have a relationship with anyone, it just means I'm not going to broadcast my conversation to the masses.
SC
SC
