Hi all,
i download just now this software and test with an italian DVD (L'albero deli zoccoli).
Conversion in mkv complete successfully in about 1h and i need to test with my xtreamer media player.
From forum i see that latest version was released at 4-mar-2010..more 1 year old
Is this project still in development?
Will be implemented in future compression feature for mkv creation?
I understand that real different between handbrake and this tool is full backup for media, correct?
For mkv file creation this tool at the moment is not capable to compress video, correct?
thanks
Marco
MakeMKV release plan and update
crowfax
Re: MakeMKV release plan and update
That's when the post was created. Not the latest version. 1.6.16 came out about a month ago.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
setarip_old
1) MakeMKV's author has stated that there is NO intention of adding compression capability to MakeMKV (There are enough other programs already available.)
2) I've never used "Handbrake", but I don't believe it can create .MKV files from Blu-ray discs or DVDs...
I haven't used Handbrake in a while (as I have no need for compression) but it looks like it can handle creating MKV's.Supported Sources:
Most common multimedia files that libavformat and libavcodec support.
Any DVD or Bluray-like source which is NOT copy-protected. (removal of copy protection is not supported)
Outputs:
File format: MP4(M4V) and MKV
Video: MPEG-4(ffmpeg), H.264(x264), or Theora(libtheora)
Audio: AAC, CoreAudio AAC (OS X Only), MP3, or Vorbis. AC-3 pass-through, DTS pass-thorugh (MKV only)
setarip_old
@SamuriHL
Hi!
Can "Handbrake" also rip commercial discs?
Hi!
joe42
Not if they are copy-protected. You'd need to remove the copy protection first, using something like MakeMKV or AnyDVD.setarip_old wrote: Can "Handbrake" also rip commercial discs?
setarip_old
That's what I thought - and that explain why users constantly talking about Handbrake still (have to) use MakeMKV (The only "one click to rip and convert to .MKV first)...
That's correct, yes. Obviously they can use any decrypter in the Handbrake workflow. Personally, I find MakeMKV to be the best MKV creation utility on the market. I have no need or desire to alter the original stream quality. That's also the heart of my persistent request to be able to default the audio tracks to HD audio, but, that's another topic altogether. In any case, yea, Handbrake can handle non-protected DVD/BD structures, but, they do need to be decrypted first.setarip_old wrote:Not if they are copy-protected.
