Should I be concerned about this log? Brand new disc
xomuz
#1 Post by xomuz » Mon Feb 03, 2025 3:24 pm
Is anything missing or broken? Should I be concerned about this log? The files seem to play fine
The King of Queens brand new disc
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Cells 7-7 were removed from title end
Title #2 was added (6 cell(s), 0:21:15)
Title #3 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title #4 was added (6 cell(s), 0:21:15)
Title #5 was added (6 cell(s), 0:21:15)
Cells 6-6 were removed from title end
Title #6 was added (5 cell(s), 0:21:14)
Title #7 was added (6 cell(s), 0:21:15)
Title #8 was added (5 cell(s), 0:21:15)
Cells 2-2 were removed from title end
Title #10 was added (1 cell(s), 0:00:14)
Can't locate a cell for VTS 11 TTN 1 PGCN 2 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 4 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 5 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 6 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 7 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 8 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 9 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 10 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 11 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 12 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 13 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 14 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 15 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 16 PGN 1
Can't locate a cell for VTS 11 TTN 1 PGCN 17 PGN 1
Title #12/1 was added (3 cell(s), 0:00:16)
Title #15 was added (5 cell(s), 0:20:59)
Saving 9 titles into directory C:/Video/The King of Queens - Season 9 Disc 1
9 titles saved
Ezatoka
Re: Should I be concerned about this log? Brand new disc
#2 Post by Ezatoka » Tue Feb 04, 2025 5:43 pm
If all six 21minutes track play without problems, I wouldn't worry.
Especially on DVDs manufacturers try to confused ripping programs with complex menu structures, which can't be accessed from a normal DVD player. MakeMKV scans all structures, and sometimes these structures end in non existing tracks. Of course nowadays that's not a problem for rippers.
