trial key issue ?
whizzard
trial key issue ?
Post by whizzard » Tue Feb 04, 2025 3:33 pm
I have been trying to use the linux version of makemkv with the trial key and it has not been working. I'll try and provide more details in subsequent posts but here are a couple of links to some of the issues that have been found. These issues do not appear to be in 1.17.7
https://github.com/automatic-ripping-ma ... ssues/1222
https://github.com/automatic-ripping-ma ... ssues/1286
Thank you.
whizzard
Re: trial key issue ?
Post by whizzard » Thu Mar 06, 2025 7:52 pm
Has no one had/got the issue where the program hangs and uses CPU whenever you run
makemkvcon info disc:9999
flojo
Post by flojo » Fri Mar 07, 2025 7:28 pm
The Linux version is known to be bugged in a few ways. There's definitely a flashing issue, a read speed issue and seemingly a issue when running a 64/32 bit OS on ARM. As long as there's no new bug fixes or feature updates, just keep using 1.17.6/7.
whizzard
Post by whizzard » Mon Mar 10, 2025 10:21 am
Thanks for the update.
It looks to me like that the dev doesn't like the command line tools and is looking to deprecate them. I hope that doesn't happen. I'm using 1.17.8 which seems passable, I just worry about the trial key expiration.
Thanks for replying.
qupfer
Post by qupfer » Tue Mar 11, 2025 9:29 am
Not Self tested, Bus did you try to add the manually to the config file?
