LibreDrive for Pioneer drives
Total200Coe
I just picked up this drive. It should be able to be patched.
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
OS device name: H:
Revision: 1.02
Yes can be flashed email me see belowTotal200Coe wrote: Tue Feb 04, 2025 2:13 pm I just picked up this drive. It should be able to be patched.
OS device name: H:
Revision: 1.02
Brz42
I have bought the following drive "ASUS SBW-06D5H-U" and are able to rip my BluRay discs at a slow 2x speed. The drive is supposed to support 6x for BluRay but RipLock apparent invalidates that for no reason. Looking into it i've found this thread and tried reading up.
MakeMKV says:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: xxx
Firmware date: 2023-04-20
Highest AACS version: 40
Firmware version: ID26
I see this in the currently supported list:
"ASUS-SBW-06D5H-U-E101-3F03CED5-8511ID26-20180822"
Questions:
- Does that mean Mike have to update the list to support this new version or is it required that my drive get a firmware downgrade?
- Some replies indicate an update to the program and others that it can be flashed or is that only if you want UHD support?
MakeMKV says:
Manufacturer: ASUS
Revision: E102
Serial number: xxx
Questions:
Pretty sure your out of luck on that one you may be able to change the speed but fw is to new to do UHD and can't be flashed at all.Brz42 wrote: Fri Feb 07, 2025 1:29 pm
MakeMKV says:
Manufacturer: ASUS
Revision: E102
Serial number: xxx
Questions:
Brz42
All my cds are straight DVD or BluRay, no 4k at all, i just want to be able to do it faster so as not to waste this much time. So will it (maybe?) be possible to get higher speeds if MakeMKV gets updated or is a flash required?Billycar11 wrote: Fri Feb 07, 2025 2:06 pm Pretty sure your out of luck on that one you may be able to change the speed but fw is to new to do UHD and can't be flashed at all.
just try speed control viewtopic.php?f=19&t=22689Brz42 wrote: Fri Feb 07, 2025 2:28 pmAll my cds are straight DVD or BluRay, no 4k at all, i just want to be able to do it faster so as not to waste this much time. So will it (maybe?) be possible to get higher speeds if MakeMKV gets updated or is a flash required?Billycar11 wrote: Fri Feb 07, 2025 2:06 pm Pretty sure your out of luck on that one you may be able to change the speed but fw is to new to do UHD and can't be flashed at all.
may not work
Brz42
Yeah, i tried setting 0=99 on my drive, but that did not change anything at all. So i'm guessing i'm stuck with this speed or have to buy another at some points. How disappointing!Billycar11 wrote: Sat Feb 08, 2025 1:43 am just try speed control viewtopic.php?f=19&t=22689
may not work
sherrypicket216
Hi! I am a new user.
I have a drive (verbatim 71097) that I bought in amazon about 1 to 2 years ago.
I just found this page an noticed that the drive was actually manufactured by pioneer.
So I want to know if the hardware is UHD compatible or not.
I am a linux user with no Windows machine on hand. It would be great if the flashing process can be done on linux.
Thank you very much for your work and help!
OS device name: /dev/sr0
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: XXXXXXXXXXXX
Firmware date: 2020-06-15
Highest AACS version: 78
Drive platform: RS8511
Firmware version: 1.14
not possible pioneers can only be flashed on windowssherrypicket216 wrote: Tue Feb 11, 2025 10:55 am Hi! I am a new user.
I am a linux user with no Windows machine on hand. It would be great if the flashing process can be done on linux.Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: XXXXXXXXXXXX Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 78 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
if you want the flasher email me see below
opened
Quick question
BDRX13JBK
firmware 1.20
BDRX13JBK
firmware 1.20
you already emailed me about this i told you i have never seen 1.20 and need full drive info to knowopened wrote: Wed Feb 12, 2025 12:16 pm Quick question
BDRX13JBK
firmware 1.20
can this be unlocked thanks
jspace
I need a couple drives for a project. I think UHD compatibility is possible with a cross flash and it is my understanding that the patched Pioneer tool is not available publicly.
Drive #1
Drive #1
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: --------
Firmware date: 2022-03-16
Highest AACS version: 21
Drive platform: RS8F00
Firmware version: 1.02/ID61
no need to post it here just email it to me see below for each drivejspace wrote: Wed Feb 12, 2025 1:18 pm I need a couple drives for a project. I think UHD compatibility is possible with a cross flash and it is my understanding that the patched Pioneer tool is not available publicly.
Drive #1Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.02 Serial number: -------- Firmware date: 2022-03-16 Bus encryption flags: 13 Highest AACS version: 21 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.02/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
jspace
But then how will I pad my post count?Billycar11 wrote: Wed Feb 12, 2025 1:26 pm no need to post it here just email it to me see below for each drive
At the very least this is another confirmation that as of February 2025 the BDR-212DBK listed on Amazon has a chance to be shipped with old enough firmware.
The manufacture date is September 2023.
belze
Can this drive be made to read and rip UHD discs?
I tried one and it would not be recognized, thanks for any help!
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.50
Serienummer: ...
Firmware-Datum: 2017-12-21
Drive platform: RS8601
Firmware version: 8.50/ID52
