ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
Post by dcoke22 » Mon Feb 03, 2025 10:03 pm
MrMustardsMayhem wrote: Sun Feb 02, 2025 11:24 pm I'm following the guide but my Mac won't open any of the files I downloaded
On a Mac, you have to use the command line instructions. That involves using the Terminal application.
If you can 'borrow' a Windows PC and get your drive connected to it, you can install MakeMKV and use the SDFtool Flasher.
zauberpilz
Post by zauberpilz » Tue Feb 04, 2025 3:04 am
I'm so happy to have found this Site. And it will even be a better month with your Help :D
Laufwerksinformation
OS-Gerätename: N:
Aktuelles Profil: CD-ROM
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: ..
Firmware-Datum: 2017-04-18
Firmware version: ID22
Disk-Informationen
Label: DM
Zeitstempel: 2021-04-07 09:41:00
Datenkapazität: 0.0 Gb
Thanks for your Work ;-)
MrMustardsMayhem
Post by MrMustardsMayhem » Sat Feb 08, 2025 4:23 am
dcoke22 wrote: Mon Feb 03, 2025 10:03 pm
I borrowed a PC but am unsure of which firmware to flash from the "This Is All You Need Firmware Pack" folder, I'd assume ASUS? I ended up flashing the Asus 5.25 BW-16D1HT but the disk tray is not opening it just flashes LED's
MrMustardsMayhem
Post by MrMustardsMayhem » Sat Feb 08, 2025 4:25 am
I flashed it to this but it doesn't seem to be working
**Drive Information**
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ...
Bus encryption flags: 1F
**LibreDrive Information**
Firmware version: 3.10
**No disc inserted**
zittrig
Post by zittrig » Sat Feb 08, 2025 11:36 pm
MrMustardsMayhem wrote: Sat Feb 08, 2025 4:23 am
Never flash a firmware for an internal drive to an external one. You could brick the drive. Try the recovery mode. First choose the wrong firmware BW-16D1HT and for the reflash the BU40N 1.03MK.
Post by d00zah » Sun Feb 09, 2025 12:11 am
zittrig wrote: Sat Feb 08, 2025 11:36 pm Never flash a firmware for an internal drive to an external one. You could brick the drive. Try the recovery mode. First choose the wrong firmware BW-16D1HT and for the reflash the BU40N 1.03MK.
More precisely...
Crossflashing Warnings:
1. Don't crossflash desktop drives to slim drives or the other way around
2. ...
zittrig
Post by zittrig » Sun Feb 09, 2025 12:36 am
d00zah wrote: Sun Feb 09, 2025 12:11 am
More precisely...
2. ...
Thanks, that's right, of course. :!: :wink:
revere
Post by revere » Sun Feb 16, 2025 4:51 pm
Hi coopervid, can you please assist in getting Libredrive firmware for my drive?
Stasjon informasjon
Operativsystemets stasjons navn: D:
Produsent: ASUS
Produkt: SBC-06D2X-U
Revisjon: 1.10
Serienummer:
Firmware dato: 2017-04-18
Krypteringsflagg for databus: 1B
Drive platform: RS8591
Firmware version: 1.10/ID22
Post by Coopervid » Sun Feb 16, 2025 6:08 pm
zauberpilz wrote: Tue Feb 04, 2025 3:04 am I'm so happy to have found this Site. And it will even be a better month with your Help :D
OS-Gerätename: N:
Produzent: ASUS
Revision: 1.10
Serienummer: ..
Disk-Informationen
Label: DM
PM sent.
Post by Coopervid » Sun Feb 16, 2025 6:09 pm
revere wrote: Sun Feb 16, 2025 4:51 pm Hi coopervid, can you please assist in getting Libredrive firmware for my drive?
Stasjon informasjon
Produsent: ASUS
Revisjon: 1.10
Serienummer:
PM sent.
NotitaPls
Post by NotitaPls » Tue Feb 18, 2025 1:51 am
Hello, I have the Asus SBW-06D2X-U and I wanted to know how to flash it to be able to rip UHD discs.
This is my MakeMKV info:
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number: ...
Firmware date: 2121-06-28 13:41
Thanks in advance.
zittrig
Post by zittrig » Tue Feb 18, 2025 4:19 am
The platform MT1959 points out to a LG drive, which is working in the enclosure. Try flashing to LG BU40N 1.03MK. All you need (flashing tool, firmware pack), you'll find here in the first post ....viewtopic.php?f=16&t=19634
NotitaPls
Post by NotitaPls » Tue Feb 18, 2025 5:52 pm
Thank u so much, it worked!!
halomadman5
Post by halomadman5 » Tue Feb 18, 2025 10:15 pm
I'm looking to flash my drive to Libredrive friendly firmware. Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number: ****************
Firmware date: 2017-04-18
Highest AACS version: 61
MrMustardsMayhem
Post by MrMustardsMayhem » Wed Feb 19, 2025 5:36 am
I used recovery mode and it successfully finished then I used Write for the LG Slim BP50NB40-N850 but an error message pops up with "Command Produced Error Code 0xxff05c103"
