md -8107-u3 stopped working with some uhd
flawlesssphere
#1 Post by flawlesssphere » Sun Feb 02, 2025 6:15 pm
I'm having a weird issue with my archigon slim external drive(md-8107-u3). After flashing to DE_LG_BU40N_1.03_MK.bin everything worked fine for a few days and then suddenly I could no longer read some uhd discs I had already read previously. The two titles this is occurring with are the boy and the heron and parasite. I tried flashing to 1.01 but it didn't seem to help. I tested both discs in a sony x700 and they both played fine. Here's my stats from makemkv:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Serial number: [redacted]
Firmware date: 2116-12-20 15:28
Highest AACS version: 77
Firmware version: 1.00
flawlesssphere
Re: md -8107-u3 stopped working with some uhd
#2 Post by flawlesssphere » Sun Feb 02, 2025 7:52 pm
After reviewing the differences between the uhds that did work and the ones that didn't I realized it's only the bd-100 discs that are showing no disc. Anyone have the same issue and found a solution? Is there any danger trying the different firmwares inside the slim exterior folder?
#3 Post by Coopervid » Sun Feb 02, 2025 8:57 pm
flawlesssphere wrote: Sun Feb 02, 2025 7:52 pm After reviewing the differences between the uhds that did work and the ones that didn't I realized it's only the bd-100 discs that are showing no disc. Anyone have the same issue and found a solution? Is there any danger trying the different firmwares inside the slim exterior folder?
Wash your discs with warm water and liquid soap. Dry with paper towel. Wippe with a microfiber cloth as used for cleaning glasses. Try again. If not successful, return the discs.
flawlesssphere
#4 Post by flawlesssphere » Sun Feb 02, 2025 9:51 pm
Alright I tried one and it still didn't work. I'm a bit perplexed as too how they got damaged when I put them right back in the box after I ripped them. Are there drives that perform better on triple layer discs? Or does everyone struggle with how finicky these things are?
flawlesssphere
#5 Post by flawlesssphere » Sun Feb 02, 2025 10:37 pm
I Figured it out! It wasn't the discs being dirty it was the firmware. I flashed the Buffalo BU12 and it's working now. :D
#6 Post by Coopervid » Sun Feb 02, 2025 11:26 pm
flawlesssphere wrote: Sun Feb 02, 2025 10:37 pm I Figured it out! It wasn't the discs being dirty it was the firmware. I flashed the Buffalo BU12 and it's working now. :D
That's weird. I can't believe.
flawlesssphere
#7 Post by flawlesssphere » Sun Feb 02, 2025 11:33 pm
I do only have a sample size of two for my experience lol, but I didn't even try cleaning the second one. It's also way faster at decrypting now.
#8 Post by Coopervid » Sun Feb 02, 2025 11:39 pm
flawlesssphere wrote: Sun Feb 02, 2025 11:33 pm I do only have a sample size of two for my experience lol, but I didn't even try cleaning the second one. It's also way faster at decrypting now.
So what firmware did you flash?
flawlesssphere
#9 Post by flawlesssphere » Sun Feb 02, 2025 11:50 pm
From the flashing guide download in the slim external folder i used DE_Buffalo_BRUHD-PU3_BU12-MK.bin
Yethidran
#10 Post by Yethidran » Mon Feb 03, 2025 2:25 am
that is interesting, i have 1 BU40N, i will try to flash it to the Buffalo firmware. maybe that firmware constructed by Buffalo has some better internal firmware instructions to read 100GB discs. that would definitely be a better firmware to flash than the LG Bu40N firmware.
thanks for the heads up.
Yethidran
#11 Post by Yethidran » Mon Feb 03, 2025 2:36 am
OS device name: I:
Revision: BU12
Serial number: ...
Firmware date: 2119-02-23 09:22
Bus encryption flags: 1F
Highest AACS version: 68
Firmware version: 0.BU12O
Disc Information
Label: DUNKIRK
Timestamp: 2017-11-08 19:26:16
Protection: AACS2.0/C v61
Data capacity: 52.98 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Yethidran
#12 Post by Yethidran » Mon Feb 03, 2025 2:39 am
OS device name: \Device\CdRom4
Revision: BU12
Serial number: ...
Disc Information
Label: OBLIVIONUHD_UPK1
Timestamp: 2016-07-05 11:51:42
Protection: AACS2.0/C v60
Data capacity: 60.88 Gb
Number of layers: 2
Yethidran
#13 Post by Yethidran » Mon Feb 03, 2025 2:42 am
1) Dunkirk is 52.98 GB
2) Oblivion is 60.88 GB
So i think i am gonna stick to the Buffalo Firmware, instead of the regular LG Firmware.
#14 Post by Billycar11 » Mon Feb 03, 2025 2:49 am
Yethidran wrote: Mon Feb 03, 2025 2:42 am 1) Dunkirk is 52.98 GB
its lg fw with a different name...
all this users drive needed was a reboot but they panicked reflashed and then it worked
Yethidran
#15 Post by Yethidran » Mon Feb 03, 2025 2:55 am
guess so, but i was kinda interested in the 100GB disc ripping without hiccups.
so maybe there is some truth in the way "Buffalo" constructed their firmware.
just always trying out new things. no harm i guess, hehehehe!!
