It is indeed! Worked like a charm! Many thanks!Coopervid wrote: Tue Jan 14, 2025 10:31 pmYour boat is floating.Cush1978 wrote: Tue Jan 14, 2025 9:44 pm I think I'm in the same boat here:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
BDR-XD07B UHD Flash
Cush1978
Re: BDR-XD07B UHD Flash
PM sent.LordBrandon wrote: Wed Jan 15, 2025 1:24 am So it looks like I was fortunate enough to buy a drive that can support UHD disks, but it seems I need help in order for it to do so.
Is there someone who can help me to get it working?
OS device name: H:
Revision: 1.03
Serial number: ---
Highest AACS version: 56
I took out the serial number but can give it if needed.
Brandon
LordBrandon
Awesome! Where can I donate to say thank you?
tparty89
Can I join in on the fun?
OS device name: E:
Revision: 1.02
Firmware date: 2019-09-05
Firmware version: 1.02
Disc Information
Disc is being loaded
OS device name: E:
Revision: 1.02
Disc Information
PM senttparty89 wrote: Wed Jan 22, 2025 10:08 pm Can I join in on the fun?
OS device name: E:
Revision: 1.02
Disc Information
Garfield
I sure appreciate the help!
OS device name: /dev/sr1
Revision: 1.03
Serial number: ...
Revision: 1.03
Serial number: ...
PM sent.Garfield wrote: Tue Jan 28, 2025 6:46 pm I sure appreciate the help!
Revision: 1.03
Serial number: ...
Garfield
Great, yes, please send next PM.
gt500
it's possible to crossflash XD07BT to XD07UHD?
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.05
Serienummer: ...
Firmware-Datum: 2023-01-06
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 72
Drive platform: Pioneer RS8D30
Firmware version: GENE
Keine Disk eingelegt
best regards
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.05
Serienummer: ...
best regards
Not possible. Pioneer disabled the ability to update your firmware.Firmware-Datum: 2023-01-06
gt500
ok, thank you.Woodstock wrote: Sun Feb 02, 2025 5:22 pmNot possible. Pioneer disabled the ability to update your firmware.Firmware-Datum: 2023-01-06
moxyland
I’ve had this drive (BDR-XD07B) for a while, for backing up DVD/Blu discs. If I understand this thread correctly I can flash it to unlock UHD read capability? (I’m on MacOS 15.3)
MakeMKV info below:
Revision: 1.03
Serial number: …
MakeMKV info below:
Revision: 1.03
Serial number: …
you need windows if you have that email me that drive info and I'll send you a flasher see belowmoxyland wrote: Sun Feb 09, 2025 5:39 pm I’ve had this drive (BDR-XD07B) for a while, for backing up DVD/Blu discs. If I understand this thread correctly I can flash it to unlock UHD read capability? (I’m on MacOS 15.3)
MakeMKV info below:
Revision: 1.03
Serial number: …
moxyland
ty Billycar11, email sent
Ruiji
Here's my drive information if anyone can help me out:
OS device name: F:
Revision: 1.03
Highest AACS version: 68
OS device name: F:
Revision: 1.03
