BDR-XD07B UHD Flash
Cush1978
Re: BDR-XD07B UHD Flash
Post by Cush1978 » Wed Jan 15, 2025 3:35 am
Coopervid wrote: Tue Jan 14, 2025 10:31 pm
Cush1978 wrote: Tue Jan 14, 2025 9:44 pm I think I'm in the same boat here:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
Your boat is floating.
It is indeed! Worked like a charm! Many thanks!
Post by Coopervid » Wed Jan 15, 2025 10:50 am
LordBrandon wrote: Wed Jan 15, 2025 1:24 am So it looks like I was fortunate enough to buy a drive that can support UHD disks, but it seems I need help in order for it to do so.
Is there someone who can help me to get it working?
OS device name: H:
Revision: 1.03
Serial number: ---
Highest AACS version: 56
I took out the serial number but can give it if needed.
Brandon
PM sent.
LordBrandon
Post by LordBrandon » Wed Jan 15, 2025 4:46 pm
Awesome! Where can I donate to say thank you?
tparty89
Post by tparty89 » Wed Jan 22, 2025 10:08 pm
Can I join in on the fun?
OS device name: E:
Revision: 1.02
Firmware date: 2019-09-05
Firmware version: 1.02
Disc Information
Disc is being loaded
Post by Coopervid » Thu Jan 23, 2025 11:22 am
tparty89 wrote: Wed Jan 22, 2025 10:08 pm Can I join in on the fun?
OS device name: E:
Revision: 1.02
Disc Information
PM sent
Garfield
Post by Garfield » Tue Jan 28, 2025 6:46 pm
I sure appreciate the help!
OS device name: /dev/sr1
Revision: 1.03
Serial number: ...
Post by Coopervid » Wed Jan 29, 2025 8:03 pm
Garfield wrote: Tue Jan 28, 2025 6:46 pm I sure appreciate the help!
Revision: 1.03
Serial number: ...
PM sent.
Garfield
Post by Garfield » Wed Jan 29, 2025 10:59 pm
Great, yes, please send next PM.
gt500
Post by gt500 » Sun Feb 02, 2025 3:38 am
it's possible to crossflash XD07BT to XD07UHD?
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.05
Serienummer: ...
Firmware-Datum: 2023-01-06
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 72
Drive platform: Pioneer RS8D30
Firmware version: GENE
Keine Disk eingelegt
best regards
Post by Woodstock » Sun Feb 02, 2025 5:22 pm
Not possible. Pioneer disabled the ability to update your firmware.
gt500
Post by gt500 » Mon Feb 03, 2025 12:52 am
Woodstock wrote: Sun Feb 02, 2025 5:22 pm
ok, thank you.
moxyland
Post by moxyland » Sun Feb 09, 2025 5:39 pm
I’ve had this drive (BDR-XD07B) for a while, for backing up DVD/Blu discs. If I understand this thread correctly I can flash it to unlock UHD read capability? (I’m on MacOS 15.3)
MakeMKV info below:
Revision: 1.03
Serial number: …
Post by Billycar11 » Mon Feb 10, 2025 3:45 am
moxyland wrote: Sun Feb 09, 2025 5:39 pm I’ve had this drive (BDR-XD07B) for a while, for backing up DVD/Blu discs. If I understand this thread correctly I can flash it to unlock UHD read capability? (I’m on MacOS 15.3)
MakeMKV info below:
Revision: 1.03
Serial number: …
you need windows if you have that email me that drive info and I'll send you a flasher see below
moxyland
Post by moxyland » Mon Feb 10, 2025 5:10 pm
ty Billycar11, email sent
Ruiji
Post by Ruiji » Mon Feb 17, 2025 10:24 pm
Here's my drive information if anyone can help me out:
OS device name: F:
Revision: 1.03
Highest AACS version: 68
