Is my pioneer BDR-XD05s flashable?
mrhex
Re: Is my pioneer BDR-XD05s flashable?
Post by mrhex »
I have combed through the forum postings. I believe that I have a later revision of the same drive jibanyanlnewells has. My question how do I go about changing the firmware on this drive to support LibreDrive?
Thanks in advance.
Here is the info dump from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ------------
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
BAKup
Post by BAKup »
Is mine able to be flashed?
OS device name: F:
Revision: 3.01
Serial number: ...
Firmware date: 2014-12-26
Highest AACS version: 68
Drive platform: RS8231
Firmware version: 3.01/ID34
mmerrylees
Post by mmerrylees »
is my bdr-xd05 able to be flasheable?
OS device name: E:
Revision: 3.10
Serial number: ...
Highest AACS version: 23
thank you in advance.
bragger3001
Post by bragger3001 »
I have the same question. Thanks!
I'm sick and tired of one-time-posters. Either participate in he forum until you have 8 posts to PM or ask Marty or Billy and pay your $25, Which is a good deal.
Powerkey
Post by Powerkey »
I just found this topic and realized I have one of these drives collecting dust.
Is this useable for UHD?
Revision: 1.21
Serial number: ---
Firmware date: 2014-04-02
Highest AACS version: 81
Firmware version: 1.21
Yethidran
Post by Yethidran »
its gotta be "Flashed"
Yethidran
Post by Yethidran »
after flashing, the xd05 will become a xd06u.
and it will be totally libre enabled to read and rip 4k uhd's.
Powerkey wrote: Sun Feb 09, 2025 7:39 am I just found this topic and realized I have one of these drives collecting dust.
Revision: 1.21
Serial number: ---
you can email me for the auto flasher for it
Powerkey
Post by Powerkey »
Thanks. Email sent.
pitt1717
Post by pitt1717 »
OS device name: /dev/sr0
Revision: 3.10
Serial number: ...
Looks like mine is similar to others.... im on linux but do have a windows machine if needed. Thank you in advance
pitt1717
Post by pitt1717 »
i guess this was directed at me?
So i do understand the 1 post feeling. But i have been using makemkv for years and really never have an issue with the software. So there was really no reason to join as i just lurked. Like how i came across this post as i was reinstallling on my Debian laptop. and following the linux guide.
Most of the time forums are for people who have issues and post to look for help or just to complain. When i join a forum, its usually based on a product i am using and looking for help or guidance. Or on the rare occasion i chime in if i feel like i can assist.
With this software, its usually set it and forget it and never have an issue like i said, but now seeing that there's possibly a route to make my hardware work with discs i thought i had to upgrade to use, i joined with the hopes of getting help to do that.
in the end, i guess ill never meet the requirement you set forth as i don't want to post garbage just for the sake of posting garbage. Again, if i post i hope to contribute not create noise.
anyway, thanks for listening and will always be grateful to the developers of this project as it is one of the most solid pieces of software i use (ripped over 320 discs and counting).
Slow down and with some more posts you are elegible to do PMs. Then do so.
pitt1717
Post by pitt1717 »
Coopervid wrote: Wed Feb 19, 2025 11:02 pm Slow down and with some more posts you are elegible to do PMs. Then do so.
didn't know there was a post count for pm's. i guess i read to much into that post
