Im sorry if this is a common question but I havent been able to find a conclusive answer to this.
I just flashed my drive and was curious if now it can also read any region disc along with being able to read 4k.
Cheers!
Does Flashing A Drive Make It Region Free?
thegeekvariety
Re: Does Flashing A Drive Make It Region Free?
Flashing does not make a drive region free. All good ripping software should ignore or remove any region coding. FYI, 4k UHD discs are region free.thegeekvariety wrote: ↑Sun Feb 02, 2025 2:02 amIm sorry if this is a common question but I havent been able to find a conclusive answer to this.
Cheers!
thegeekvariety
Thanks for the clarification, appreciate it.MartyMcNuts wrote: ↑Sun Feb 02, 2025 3:06 amFlashing does not make a drive region free. All good ripping software should ignore or remove any region coding. FYI, 4k UHD discs are region free.thegeekvariety wrote: ↑Sun Feb 02, 2025 2:02 amIm sorry if this is a common question but I havent been able to find a conclusive answer to this.
Cheers!
