Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
Deleted. Responded already to another post.
IShopper42
Hi Billycar11,
Regards,
Ian.
I took a gamble and purchased a BDR-212DBK from an Amazon sale. The drive was manufactured in October 2024 but appears to have older firmware:Billycar11 wrote: ↑Mon Dec 16, 2024 3:47 pmNo return it I still have the newest gen pioneers with old fw if you want one see belowIShopper42 wrote: ↑Mon Dec 16, 2024 3:40 pmHi Billycar11,
I ordered a BDR-212V from Vinpower Digital's Australian office. The drive I was shipped is labeled as a DBR-212BK. I was told to test the drive to see if it is UHD enabled. This is what I get from MakeMKV:Is this drive unlockable?Drive Information
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: (Redacted)
Firmware date: 2022-12-20
Firmware version: ID81
Regards,
Ian.
Have I lucked out with an unlockable drive this time? If so, can you help me out with the appropriate firmware and instructions?Drive Information
OS device name: E:
Product: BD-RW BDR-212D
Revision: 1.02
Firmware date: 2022-03-16
Bus encryption flags: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
Regards,
Ian.
After reading recommendations I landed with:
In the debug logs:
Your help is greatly appreciated.
BTW: Tried to create a new post, however as a newbie to this forum either was not successful or blocked by moderations filters.
OS device name: /dev/sr1
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CIDL001355WL
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
No disc insertedCode: Select all
No SDF v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
SDF id v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WLYour help is greatly appreciated.
yeah you are in luck email me that info belowIShopper42 wrote: ↑Sun Jan 26, 2025 11:37 amHi Billycar11,
Regards,
Ian.Have I lucked out with an unlockable drive this time? If so, can you help me out with the appropriate firmware and instructions?Drive Information
OS device name: E:
Revision: 1.02
Regards,
Ian.
IShopper42
Hi Billycar11,
Thank you.
Regards,
Ian.
Email message sent.
Thank you.
Regards,
Ian.
This drive is incompatible. It has the post 11/2022 firmware and cannot be flashed at all. Return it if you can.andser wrote: ↑Sun Jan 26, 2025 12:50 pmAfter reading recommendations I landed with:
In the debug logs:Code: Select all
Drive Information OS device name: /dev/sr1 Manufacturer: PIONEER Product: BD-RW BDR-XD08U Revision: 1.02 Serial number: CIDL001355WL Firmware date: 2022-12-27 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9331 Firmware version: ID05 No disc inserted
No SDF v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL SDF id v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
smaxsomeass
is this drive good to flash for uhd use? may i have the instructions please?
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ...
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
Revision: 1.02
Serial number: ...
PM sent.smaxsomeass wrote: ↑Sat Feb 01, 2025 8:34 pmis this drive good to flash for uhd use? may i have the instructions please?
Revision: 1.02
Serial number: ...
smaxsomeass
Yes, please send next PMCoopervid wrote: ↑Sat Feb 01, 2025 10:00 pmPM sent.smaxsomeass wrote: ↑Sat Feb 01, 2025 8:34 pmis this drive good to flash for uhd use? may i have the instructions please?
Revision: 1.02
Serial number: ...
PM sent.smaxsomeass wrote: ↑Sat Feb 01, 2025 11:19 pmYes, please send next PMCoopervid wrote: ↑Sat Feb 01, 2025 10:00 pmPM sent.smaxsomeass wrote: ↑Sat Feb 01, 2025 8:34 pmis this drive good to flash for uhd use? may i have the instructions please?
Revision: 1.02
Serial number: ...
smaxsomeass
I have a Pioneer BDR-212V that is coming from Runtechmedia. Fingers crossed that it doesn't come with a newer firmware after 2022. Will report back.
Reporting back that my order arrived and did not have a firmware after 2022.
@Coopervid, can you please help me to enable UHD ripping on this pioneer model? Thanks in advance.
Here is the info I got from MakeMKV:
Revision: 1.02
Serial number: XXXXX
Highest AACS version: 77
Revision: 1.02
vmware-fanboy
Thank you - worked.Coopervid wrote: ↑Fri Jan 17, 2025 11:25 amPM sent.vmware-fanboy wrote: ↑Thu Jan 16, 2025 4:12 pmHello Coopervid I have just purchased Pioneer BDR-212V with drive information below.
Can you please advise me on next steps for libredrive firmware?Code: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06 No disc inserted
Thank you very much.
ImDeranged
I just replaced my LG drive with one of the BD-RW BDR-212V from Amazon. Info is. It's already done a disc two other drives couldn't read.
"Drive Information
Current profile: DVD-ROM
Revision: 1.02
Serial number: ...
Firmware version: ID06"
I'd also like info on unlocking UHD. Thank you in advance.
"Drive Information
Revision: 1.02
Serial number: ...
