MakeMKV can't find optical drive
averma24
Post by averma24 » Fri Jan 31, 2025 6:44 pm
Hi
I compiled and istalled both packages on my linux computer .
It works but , it can't see the optical drive . With or without a disk inside . Mounted or not .
It works fine using a ISO file .It sees and extracts the content .
Here is the content of MakeMKV_log.txt file :
Debug log started at Fri Jan 31 19:31:18 2025 , written by MakeMKV v1.17.8 linux(x64-release)
001005:0000 MakeMKV v1.17.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///root/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at &E)F2X}$1{zkZ?]!^aPSC@)@:121261428
005042:0000 The program can't find any usable optical drives.
My questions are :
Can I point the program to a location to find the drive ?
Is there such an option , at least from the terminal ?
My drive can be found at /dev/sr0 .
VLC finds the drive , PBurn ( burns discs ) finds the optical drive .
Edit :
I must add that I used an USB attached external drive an old Philips SPB3000CC , which is a DVD/CD drive .
Looking more on the forum pages , I uderstand that my kernel is compiled without SCSI GENERIC support module , which is needed . I shall try to compile and load it.
I'll also open up my desktop , which has no space for a 5.25 drive and try to attach via SATA cables the Pioneer BDR -212V drive I just bought and give a try to MakeMKV .
Both drives showed fine in Windows 10.
averma24
Re: MakeMKV can't find optical drive
Post by averma24 » Sat Feb 01, 2025 3:57 pm
I did have the sg module but it was not loaded .
As seen in other forum's posts
modprobe sg
solved the issue .
Now MakeMKV sees optical drives , even inside usb enclosure .
It's true that when starting the program there should be no disc in the optical drive .
