Makemkv is useless
keydb_helper
Re: Makemkv is useless
#46 Post by keydb_helper » Sat Feb 01, 2025 1:12 am
Peterduke wrote: Fri Jan 31, 2025 9:24 pm I tried troubleshooting, disabling firewall, AV, adding exceptions, reinstalling Makemkv I think I’m running out of options
If your internet provider is actively blocking your connection to the server which provides keys to MakeMKV, nothing you listed will actually help address the issue. It doesn't matter if you reinstall MakeMKV or reconfigure your firewall/AV when the actual upstream connection is being blocked by the ISP.
You can either change internet provider to one which isn't so aggressive with blocking websites or use a VPN to circumvent the ISP block. Those are the two options available to you right now.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Peterduke
#47 Post by Peterduke » Sat Feb 01, 2025 3:16 am
keydb_helper wrote: Sat Feb 01, 2025 1:12 am
The ISP is blocking it and so are vpn locations in Sweden, I’d imaging that European countries block it, so just change it to Japan or somewhere like Africa and the keys downloaded just fine.
