Volume key in Madoka UHD 4k movies
Olivadiego
The new madoka magica bluray 1 and 3 is giving me the volume key is unknown error, the disk 2 is working but the other 2 movies are not
Re: Volume key in Madoka UHD 4k movies
Did you also email these to svq@makemkv.com for processing?
Olivadiego
yesWoodstock wrote: Fri Jan 31, 2025 4:40 pm Did you also email these to svq@makemkv.com for processing?
Unit keys for both titles are in the keydb. They won't help with MakeMKV directly but if you use something like Xreveal you can decrypt the discs and then open them with MakeMKV.
Olivadiego
it worked, thank you so muchSamuriHL wrote: Fri Jan 31, 2025 5:53 pm Unit keys for both titles are in the keydb. They won't help with MakeMKV directly but if you use something like Xreveal you can decrypt the discs and then open them with MakeMKV.
keydb_helper
Thank you for providing the disc dump files. Both discs now have complete entries in the public keydb, so they can be processed by MakeMKV without requiring XReveal.Olivadiego wrote: Fri Jan 31, 2025 4:38 pm The new madoka magica bluray 1 and 3 is giving me the volume key is unknown error, the disk 2 is working but the other 2 movies are not
Public KeyDB Disc Submissions
