Just wondering if this my Drive needs to be flashed for MKV to rip UHD
Maffo
Re: Just wondering if this my Drive needs to be flashed for MKV to rip UHD
Post by Maffo »
Yeah the errors
Can't read AACS VID from disc - most likely current AACS host cer8tificate is revoked by your drives
Saved AACS dump file as MakeMKV RETA po. Can't be decrypted.
V6 1 INTERSTELLAR_505B toz
LibreDrive compatible driv
Backup failed
Maffo wrote: Fri Jan 31, 2025 10:18 pm Yeah the errors
Backup failed
Have you flashed the drive yet? Show us the MakeMKV info.
Maffo
Post by Maffo »
hi Here is the new drive info
OS device name: G:
Product: BD-RE BU40N
Revision: 1.03
Serial number: KZZI3TH0546
Highest AACS version: 61
Firmware version: 1.03
fir3fox
Post by fir3fox »
Drive dont know the media inserted, I try to play Venom 4 Ultrahd disc. its a Asus BW-16D1HT with f/w V3.10
Here is more info from MakeMKV, running win 10 Pro, Is it possible to play this media, I have read on this forum its possible...
//Regards fir3fox
Post by d00zah »
You'll need to flash new FW. Refer to 1st post of the guide.
Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK
File name: ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Using SDFtool Flasher
fir3fox
Post by fir3fox »
Thank you for fast answer and I realy appreciate it from you...
Do I need to set the computer in safe mode or I can update the f/w when its up n running ?
I have download those files, but was a bit unsure of how to set my computer in safe mode or up n runnig as well.
//fir3fox
No safe mode needed.
fir3fox
Post by fir3fox »
It works, now I'm able to read those 4k Ultra HD media.
Thank you very much...
//fir3fox
Maffo
Post by Maffo »
OS device name: G:
Revision: 1.03
Serial number:
works with a DVD fine makemkv but it put it in a iso file but UHD dont work :(
zittrig
Post by zittrig »
Hallo again ....
Have you tested it with several 4k discs like adviced in the other topic or only with the one you had? Clean disc? No srcatches? Initialisation with Windows before openig the MakeMKV app?
Maffo
Post by Maffo »
Hi there no i only have one 4K UHD disk but i have ordered some more when they come i will test them and let you know thank you
i know this is off the topic but i saved my original firmware with make mkv but i need to convert it back from tar to bin can anyone on here do it for me plz thank you
zittrig
Post by zittrig »
Why do you want do this?
From tar to bin I don't know actually, but you can flash the original 1.00 for the BU40N which can be found in the all-you-need firmware pack.
Maffo
Post by Maffo »
Hi there i always like to keep my original firmware its just the way i am sorry
ive got the firmware now from where you said thank you
ps my 4k UHD disks are coming on saturday so i can test them thanks
Maffo wrote: Tue Feb 04, 2025 10:06 pm Hi there i always like to keep my original firmware its just the way i am sorry
That tgz dump is not the firmware file. It is only the important bits like the cal data. You cannot flash this to the drive.
Maffo
Post by Maffo »
Ok thanks for that I do understand thanks
