Dump Submitted: The Sacrifice 4K
mysterysup
Dump submitted: "MKB20_v77_The_Sacrifice_16E2"
Re: Dump Submitted: The Sacrifice 4K
That one has a unit key in the keydb and matches this disc id:
Hopefully someone can come along and add the VUK for it, as well so that MakeMKV can use it. In the meantime you could use Xreveal to decrypt the disc so you could open it with MakeMKV.
0x6D23DC6ED89B57678B8AB04738633B3730C7D6AC
mysterysup
Working now
keydb_helper
The MK and VUK for this variant of The Sacrifice have been added to the public keydb.SamuriHL wrote: Fri Jan 31, 2025 7:42 pm That one has a unit key in the keydb and matches this disc id:
Hopefully someone can come along and add the VUK for it, as well so that MakeMKV can use it. In the meantime you could use Xreveal to decrypt the disc so you could open it with MakeMKV.Code: Select all
Public KeyDB Disc Submissions
