ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
Post by Coopervid » Sun Jan 26, 2025 9:44 pm
ShadowSorcery wrote: Sun Jan 26, 2025 1:32 pm now im getting this error Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00146.m2ts' at offset '0
Complety remove power. Then try again.
ShadowSorcery
Post by ShadowSorcery » Mon Jan 27, 2025 6:27 am
for some reason, that fixed it thx for the help :)
bambithug
Post by bambithug » Fri Jan 31, 2025 6:43 pm
Coopervid wrote: Thu Jan 04, 2024 3:26 pmCheck PM.
Could I please have the firmware I have Pioneer RS8F00 and cant find anyway of making it work with 4k and makemkv
thank you so much
Post by Coopervid » Fri Jan 31, 2025 7:33 pm
bambithug wrote: Fri Jan 31, 2025 6:43 pm
thank you so much
Post your Makemkv info and read your PM.
HunterKiller
Post by HunterKiller » Sun Feb 02, 2025 7:17 pm
Hello!
My drive not recognized a UHD disc. It's good for flashing, guys?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: -------
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
Galvin
Post by Galvin » Mon Feb 03, 2025 5:02 pm
Hello, I am another owner of the ASUS BW-16D1H-U. Could someone help me rip UHD discs?
This is the reader's information:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 81
Disc Information
Label:
Timestamp:
Protection: AACS v66
Data capacity: 43.91 Gb
Disc type: BD-ROM
Number of layers: 2
Thank you and greetings.
HunterKiller
Post by HunterKiller » Wed Feb 05, 2025 5:53 pm
In fact, I wonder about one more thing. Will the option to burn discs that I currently have still be available after such a flash? Has anyone done this and knows? Of course, I'm thinking about Blu-ray discs.
husked
Post by husked » Wed Feb 12, 2025 2:54 pm
Hello everyone,
may you can help me with im drive which is currently blocking UHD disks:
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
Firmware-Datum: 2020-07-21
Highest AACS version: 76
Firmware version: ID76
Post by Coopervid » Wed Feb 12, 2025 10:33 pm
One-time-posters need to be more active than just one post.
husked
Post by husked » Sat Feb 15, 2025 8:30 am
Which means? I was not able to find the exact same circumstances in other postings, everything else works out fine and the software is doing its job perfectly, which is a reason to be happy :)
Post by Coopervid » Sun Feb 16, 2025 10:21 am
husked wrote: Sat Feb 15, 2025 8:30 am Which means? I was not able to find the exact same circumstances in other postings, everything else works out fine and the software is doing its job perfectly, which is a reason to be happy :)
Your drive needs to be flashed to read UHDs.
Galvin
Post by Galvin » Sun Feb 16, 2025 4:37 pm
Sorry, I don't usually use the forums too much, my experience with ripping is based on the use of my Verbatim 43888, which does not have to be modified. I already have a good number of digitized titles and I had almost no problems until I reached a couple of discs from the Game of Thrones series, with which I tried several of the tips given in this forum regarding cleaning the discs without a positive result. As a consequence, I decided to buy another reader that I saw on Amazon at a good price, the one mentioned in the post, although this one needs to be modified to read UHD discs. I would appreciate any advice on this, thank you and best regards.
Post by Coopervid » Sun Feb 16, 2025 6:13 pm
Galvin wrote: Sun Feb 16, 2025 4:37 pm Sorry, I don't usually use the forums too much, my experience with ripping is based on the use of my Verbatim 43888, which does not have to be modified. I already have a good number of digitized titles and I had almost no problems until I reached a couple of discs from the Game of Thrones series, with which I tried several of the tips given in this forum regarding cleaning the discs without a positive result. As a consequence, I decided to buy another reader that I saw on Amazon at a good price, the one mentioned in the post, although this one needs to be modified to read UHD discs. I would appreciate any advice on this, thank you and best regards.
PM sent.
Post by Coopervid » Sun Feb 16, 2025 6:16 pm
HunterKiller wrote: Sun Feb 02, 2025 7:17 pm Hello!
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
PM sent.
Post by Coopervid » Sun Feb 16, 2025 6:18 pm
PM sent.
