Pioneer BDR-XD05TS 4k compatibility?
Hi, is there a flash solution for the following drive available?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 42
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Revision: 3.01
Re: Pioneer BDR-XD05TS 4k compatibility?
Try it...zittrig wrote: Sat Nov 30, 2024 9:26 pm Hi, is there a flash solution for the following drive available?
Revision: 3.01
Finally the drive arrived!
Flashing process successful.
@Coopervid: Thanks a lot!
You are very welcome!zittrig wrote: Fri Dec 06, 2024 6:12 pm Finally the drive arrived!
Hello, I have also a BDR-XD05
Revision: 3.10
Firmware date: 2017-06-22
Highest AACS version: 68
Drive platform: RS8232
Firmware version: 3.10/ID34
What could I do to make 4k backups?
Thanks in advance
Revision: 3.10
Thanks in advance
PM sent.gruenfron wrote: Fri Jan 17, 2025 12:50 pm Hello, I have also a BDR-XD05
Revision: 3.10
Thanks in advance![]()
Attached below is the webpage to download the "Drive Utility" for settings once you have "Flashed" your XD05 to a XD06.
Cheers!
"DO NOT DOWNLOAD THE FIRMWARE UPDATE LINK!!"
JUST DOWNLOAD THE "UTILITY"
Cheers!
Hi!
What do I have to do to make the XD05TS 4k compatible?
apologies for the necro, but just so I understand, it is possible to flash a BD-RW BDR-XD05 to an XD06 for 4K UHD compatibility?
Asking because I have this drive, and it has served me well up to this point, but I just bought some UHD movies, and it isn't reading any of them. I would appreciate some help.
Thanks.
Thanks.
You guys need to post your Makemkv info.4wheels wrote: Sat Jul 05, 2025 4:17 pm Hello,
Thanks.
Sorry, I'm new at this... What info do I need to post? I'm on macOS if that matters. Here's the stuff from the main MakeMKV window
Revision: 3.01
Serial number: ...
Highest AACS version: 76
Unrestricted read speed: YesRe: Pioneer BDR-XD05TS 4k compatibility?
PM sent. You need a Windows PC or a good VM.4wheels wrote: Sun Jul 06, 2025 2:50 am Sorry, I'm new at this... What info do I need to post? I'm on macOS if that matters. Here's the stuff from the main MakeMKV window
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: ... Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
littlemo00
Would like to know if my drive can be flashed to read 4k.
Revision: 3.10
Serial number: QJDL127144UC
Highest AACS version: 81
Revision: 3.10
