full disc back up or .mkv
squirrelman10
#1 Post by squirrelman10 » Mon Nov 14, 2011 6:14 pm
so i just read that you can back up the entire disk, does it make it into an .iso?? also is the full disk back up more space than the mkv version?? what is the difference
Sion28
Re: full disc back up or .mkv
#3 Post by Sion28 » Tue Nov 15, 2011 11:35 pm
That in no way answers the OP's question.
That FAQ entry does not specify if the output is an unencrypted .ISO, or a folder of files, or if there's an option for either.
That FAQ entry also does not indicate which (backup or mkv) will take up more space on the destination media.
Can you please answer these questions? Thanks! :)
setarip_old
#4 Post by setarip_old » Wed Nov 16, 2011 12:31 am
@squirrelman10
Hi!
No.
Yes.
At the very least, a small difference would occur regarding the AACS copy protection, that doesn't get incorporated into any .MKV file.
Of course, if you make a "movie-only" .MKV, it also would not include menus or "Extras"...
bw001
#5 Post by bw001 » Mon Nov 28, 2011 2:06 am
I've found that I can use Imgburn to create an .iso from the resulting folders/files created from a full disc backup.
Crazy Marty
#6 Post by Crazy Marty » Thu Dec 29, 2011 12:33 am
Actually, using "backup" instead of "copy titles" could save a lot of space!
For instance, the Avatar Collector's Edition 1st BD can show you 3 different versions of the full movie: 1 with no scenes deleted; 1 with *some* scenes deleted; the last with *more* scenes deleted (the theatrical version). It's done by using 3 separate mpls (playlist) files (all chapters in the 1st, some missing from the 2nd, and more missing from the 3rd), so "copy titles" will get you *3* *separate* *30GB+* movies -- from a disc that only holds 50GB total.
~/makemkv/Avatar - Disc 1$ ls -1s|sort -rn
33903808 title18.mkv
32619588 title05.mkv
30549528 title06.mkv
(sizes in kilobytes).
robpdotcom
#7 Post by robpdotcom » Thu Dec 29, 2011 2:44 am
Crazy Marty wrote:Actually, using "backup" instead of "copy titles" could save a lot of space!
Search for a program called "xin1generator", it can create one MKV with all three versions of the film - something I hope to see one day in MakeMKV. I have all three versions of Avatar, with the HD audio, in one 38GB file.
Crazy Marty
#8 Post by Crazy Marty » Thu Dec 29, 2011 3:11 am
Hey, that's great -- and since the source is available under the MIT license, I believe it would be just fine to use it within makemkv! What do you think, Mike?
