Asus Turbodrive BE 16D1X-U
Peterduke
#1 Post by Peterduke » Fri Jan 31, 2025 5:12 pm
I purchased a ASUS Turbodrive BE 16D1X-U external drive and I’m wondering if anyone could help me with the firmware for it?
I want to use it to read 4k blurays with Makemkv
Thank you so much
Re: Asus Turbodrive BE 16D1X-U
#2 Post by Coopervid » Fri Jan 31, 2025 6:45 pm
Peterduke wrote: Fri Jan 31, 2025 5:12 pm I purchased a ASUS Turbodrive BE 16D1X-U external drive and I’m wondering if anyone could help me with the firmware for it?
Thank you so much
You need to post your Makemkv info.
Peterduke
#3 Post by Peterduke » Fri Jan 31, 2025 7:20 pm
I’ll grab it Ty
Peterduke
#4 Post by Peterduke » Fri Jan 31, 2025 7:26 pm
Coopervid wrote: Fri Jan 31, 2025 6:45 pm
Thank you so much
Hhh
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Firmware date: 2020-07-21
Highest AACS version: 81
Status: Possible, not yet enabled Drive platform: Pioneer RS8F00
Firmware version: ID76
#5 Post by Coopervid » Fri Jan 31, 2025 7:31 pm
Peterduke wrote: Fri Jan 31, 2025 7:26 pm
Thank you so much
Hhh
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
PM sent.
Peterduke
#6 Post by Peterduke » Fri Jan 31, 2025 7:36 pm
Coopervid wrote: Fri Jan 31, 2025 7:31 pm
Hhh
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
PM sent.
Sorry I’m flat out broke after paying £130 for this drive
#7 Post by Coopervid » Fri Jan 31, 2025 7:39 pm
Peterduke wrote: Fri Jan 31, 2025 7:36 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
PM sent.
Fine. Your decision. Return it if you can and we will find a less expensive solution.
Peterduke
#8 Post by Peterduke » Fri Jan 31, 2025 7:40 pm
I always have a less expensive solution 😀 I saw the tools you use on a polish forum so I’ll ask them instead
Thanks for your help bro
#9 Post by Coopervid » Fri Jan 31, 2025 7:41 pm
Fine.
Peterduke
#10 Post by Peterduke » Fri Jan 31, 2025 7:45 pm
Peterduke wrote: Fri Jan 31, 2025 7:20 pm I’ll grab it Ty
Peterduke
#11 Post by Peterduke » Fri Jan 31, 2025 7:48 pm
Coopervid wrote: Fri Jan 31, 2025 7:41 pmFine.
Please check dm I changed my mind
Peterduke
#12 Post by Peterduke » Fri Jan 31, 2025 8:12 pm
Hhh
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
PM sent.
Pm sent thank you
#13 Post by Coopervid » Fri Jan 31, 2025 8:19 pm
Peterduke wrote: Fri Jan 31, 2025 7:48 pm
You have the PM.
demuxme
#14 Post by demuxme » Fri Jan 31, 2025 8:27 pm
there's an entire flashing guide on the forum. Why pay?
#15 Post by Coopervid » Fri Jan 31, 2025 8:37 pm
demuxme wrote: Fri Jan 31, 2025 8:27 pm there's an entire flashing guide on the forum. Why pay?
LG / ASUS is public. Pioneer is not and it's not supposed to be. And more than 70% of the one-time-posters never read their PM and are just morons. So read through the forum and don't be an initial pest.
