Asus Turbodrive BE 16D1X-U
Peterduke
I purchased a ASUS Turbodrive BE 16D1X-U external drive and I’m wondering if anyone could help me with the firmware for it?
I want to use it to read 4k blurays with Makemkv
Thank you so much
Thank you so much
Re: Asus Turbodrive BE 16D1X-U
You need to post your Makemkv info.Peterduke wrote: Fri Jan 31, 2025 5:12 pm I purchased a ASUS Turbodrive BE 16D1X-U external drive and I’m wondering if anyone could help me with the firmware for it?
Thank you so much
Peterduke
I’ll grab it Ty
Peterduke
Drive InformationCoopervid wrote: Fri Jan 31, 2025 6:45 pmHhhPeterduke wrote: Fri Jan 31, 2025 5:12 pm I purchased a ASUS Turbodrive BE 16D1X-U external drive and I’m wondering if anyone could help me with the firmware for it?
Thank you so much
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Firmware date: 2020-07-21
Highest AACS version: 81
Status: Possible, not yet enabled Drive platform: Pioneer RS8F00
Firmware version: ID76
PM sent.Peterduke wrote: Fri Jan 31, 2025 7:26 pmDrive InformationCoopervid wrote: Fri Jan 31, 2025 6:45 pmHhhPeterduke wrote: Fri Jan 31, 2025 5:12 pm I purchased a ASUS Turbodrive BE 16D1X-U external drive and I’m wondering if anyone could help me with the firmware for it?
Thank you so much
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Peterduke
Sorry I’m flat out broke after paying £130 for this driveCoopervid wrote: Fri Jan 31, 2025 7:31 pmPM sent.Peterduke wrote: Fri Jan 31, 2025 7:26 pmDrive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Fine. Your decision. Return it if you can and we will find a less expensive solution.Peterduke wrote: Fri Jan 31, 2025 7:36 pmSorry I’m flat out broke after paying £130 for this driveCoopervid wrote: Fri Jan 31, 2025 7:31 pmPM sent.Peterduke wrote: Fri Jan 31, 2025 7:26 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Peterduke
I always have a less expensive solution
I saw the tools you use on a polish forum so I’ll ask them instead
Thanks for your help bro
Peterduke
Peterduke
Please check dm I changed my mind
Peterduke
Pm sent thank youCoopervid wrote: Fri Jan 31, 2025 7:31 pmPM sent.Peterduke wrote: Fri Jan 31, 2025 7:26 pmDrive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
demuxme
there's an entire flashing guide on the forum. Why pay?
LG / ASUS is public. Pioneer is not and it's not supposed to be. And more than 70% of the one-time-posters never read their PM and are just morons. So read through the forum and don't be an initial pest.
