Volume key in Madoka UHD 4k movies
Olivadiego
#1 Post by Olivadiego » Fri Jan 31, 2025 4:38 pm
The new madoka magica bluray 1 and 3 is giving me the volume key is unknown error, the disk 2 is working but the other 2 movies are not
Re: Volume key in Madoka UHD 4k movies
#2 Post by Woodstock » Fri Jan 31, 2025 4:40 pm
Did you also email these to svq@makemkv.com for processing?
Olivadiego
#3 Post by Olivadiego » Fri Jan 31, 2025 4:54 pm
Woodstock wrote: Fri Jan 31, 2025 4:40 pm Did you also email these to svq@makemkv.com for processing?
yes
#4 Post by SamuriHL » Fri Jan 31, 2025 5:53 pm
Unit keys for both titles are in the keydb. They won't help with MakeMKV directly but if you use something like Xreveal you can decrypt the discs and then open them with MakeMKV.
Olivadiego
#5 Post by Olivadiego » Fri Jan 31, 2025 6:25 pm
SamuriHL wrote: Fri Jan 31, 2025 5:53 pm Unit keys for both titles are in the keydb. They won't help with MakeMKV directly but if you use something like Xreveal you can decrypt the discs and then open them with MakeMKV.
it worked, thank you so much
keydb_helper
#6 Post by keydb_helper » Sat Feb 01, 2025 12:56 am
Olivadiego wrote: Fri Jan 31, 2025 4:38 pm The new madoka magica bluray 1 and 3 is giving me the volume key is unknown error, the disk 2 is working but the other 2 movies are not
Thank you for providing the disc dump files. Both discs now have complete entries in the public keydb, so they can be processed by MakeMKV without requiring XReveal.
Public KeyDB Disc Submissions
