Raiders of the Lost Ark UHD 4k Volume Key Unknown
kdubbs29
Post by kdubbs29 » Fri Jan 31, 2025 3:28 am
Not sure if anyone else is having the same problem with this disk. I submitted the dump file, and I downloaded the most up-to-date KEYDB.cfg. So, I guess at this point I just wait for the database to be updated with the info from my dump file, right?
keydb_helper
Re: Raiders of the Lost Ark UHD 4k Volume Key Unknown
Post by keydb_helper » Fri Jan 31, 2025 3:42 am
kdubbs29 wrote: Fri Jan 31, 2025 3:28 am Not sure if anyone else is having the same problem with this disk. I submitted the dump file, and I downloaded the most up-to-date KEYDB.cfg. So, I guess at this point I just wait for the database to be updated with the info from my dump file, right?
In order for your disc to be added to the public keydb.cfg file, you'll need to post your dump file here as either an attachment or a link to a filehost. A disc dump produced by an LG/Asus drive is always preferable. Otherwise, you may have to wait several days or weeks for MakeMKV to natively support your disc.
Public KeyDB Disc Submissions
kdubbs29
Post by kdubbs29 » Fri Jan 31, 2025 12:32 pm
Ahhh, good to know! Here is the link to the dump file: https://spaces.hightail.com/receive/MqAMqvaNXp. Thanks!
keydb_helper
Post by keydb_helper » Fri Jan 31, 2025 2:07 pm
kdubbs29 wrote: Fri Jan 31, 2025 12:32 pm Ahhh, good to know! Here is the link to the dump file: https://spaces.hightail.com/receive/MqAMqvaNXp. Thanks!
Thanks for the dump file. Could you please also upload the complete 'AACS' folder from your disc? The dump file you provided is a partial dump file (~150-250KB) which omits most of the 'AACS' folder.
(Regular dump files are 3-5MB and include the entire AACS folder. Partial dump files are generally created for older titles where MakeMKV already has support for a 'sibling' disc variant)
Edit: Support for your disc has been added to the public keydb. It is possible that the submitted entry isn't correct but that would require some tremendous coincidences. That AACS folder would still be useful for verification purposes.
kdubbs29
Post by kdubbs29 » Fri Jan 31, 2025 4:07 pm
keydb_helper wrote: Fri Jan 31, 2025 2:07 pm
Ah, gotcha. Here is the complete AACS folder from the disc. https://spaces.hightail.com/receive/MttVzjafI2. This link expires in 7 days.
Thank you so much for your help!
keydb_helper
Post by keydb_helper » Sat Feb 01, 2025 12:51 am
kdubbs29 wrote: Fri Jan 31, 2025 4:07 pm Ah, gotcha. Here is the complete AACS folder from the disc. https://spaces.hightail.com/receive/MttVzjafI2. This link expires in 7 days.
Thank you for providing the AACS folder. The public keydb entry which was added earlier today should work with your particular disc.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
kdubbs29
Post by kdubbs29 » Sat Feb 01, 2025 4:10 pm
Thank you! It worked!!!
