ripping megamind from bdmv folder on hard drive
dee6567
#1 Post by dee6567 » Mon Nov 14, 2011 3:40 pm
hi
i am new to this and just wondering why i am having problems ripping megamind from a iso i aquired.
from the iso i extracted megamind using power iso which was 42gb.
tried making a mkv from the bdmv folder removing everything except true hd ,ac3 and movie file.
when it completes it has only ripped half of the movie.
i cant understand what has happened to the rest of the film.
i have made mkv movies in this way before and never had problems with other movies.
please can someone tell me whats going on. its driving me mad.
thanks
setarip_old
Re: ripping megamind from bdmv folder on hard drive
#2 Post by setarip_old » Mon Nov 14, 2011 6:34 pm
For discussion at this forum (and most other technical forums), you should be using ONLY original, commercial discs as your initial source material.
dee6567
#3 Post by dee6567 » Mon Nov 14, 2011 9:51 pm
hi
sorry for misrepresenting my earlier request.
i made the back up from my original blue ray dics.
i tried making the mkv direct from the disc and got the same result.
this is why i backed it up as an iso and tried it this way and got same results.
thanks
setarip_old
#4 Post by setarip_old » Mon Nov 14, 2011 10:34 pm
Then you've made it clear that your original, commercial disc (your INITIAL source for all of your efforts) is damaged.
Return it to the place of purchase in exchange for a new one...
dee6567
#5 Post by dee6567 » Tue Nov 15, 2011 9:31 am
hi
if the movie is the problem why does it play in my blue ray player without any problems.
i dont get it
