Yes, please send the next PMtraveler286 wrote: Mon Jan 27, 2025 10:19 pm @coopervid,
I too would like instructions to upgrade my BDR 212V for 4K Ultra disk reading for Plex server. I just registered so cannot directly PM you yet.
BDR 212V UHD Guide
traveler286
Re: BDR 212V UHD Guide
@coopervid Thank you very much
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: ...
Firmware date: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
traveler286
Thanks Coopervid.
I was planning to purchase a license instead of a donation. I am just starting my journey into Plex Media server and have a lot to process including audio CDs. I have 16TB of storage and cloud backup.
Hi @Coopervid!BarryR wrote: Mon Jan 27, 2025 11:00 pm @Coopervid
Was wondering if you could steer me in the right direction. I have same drive as many above
OS device name: F:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
I have bought an "ASUS Extern BDWriter BW- 16D1X-U". It says in MakeMKV that it has Drive platform: Pioneer RS8F00. Is it possible to get this drive to read 4k disc?
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: **************
Firmware date: 2020-07-21
Highest AACS version: 64
Firmware version: ID76
A licence will not fix your drive. Post your Makemkv info.traveler286 wrote: Thu Jan 30, 2025 5:47 pm Thanks Coopervid.
Hi Coopervid
Today I just got my Pioneer BDR-212V drive from amazon .
As lately some of the new bought Pioneer drives have newer firmware , I was unsure if shall be lucky .
On the label of my drive the MFD date is 2024-03
However , Makemkv says different :
OS device name :E:
Manufacturer : PIONEER
Product : BD-RW BDR-212V
Revision :1.02
Serial number :XXXXXXXXX
Firmware date :2022-05-31
Bus encryption flags :13
Status: Possible , not yet enabled
Drive platform : Pioneer RS8F00
Firmware version : ID06
No disk inserted I used the drive inside a OWC Mercury PRO enclosure , usb attached .
No info about Highest AACS version
Which steps should I take in order to flash my drive ?
I'm new to the forum , I don't think I am able to get PMs.
Thank you in advance .
OS device name :E:
Revision :1.02
Anybody please help me with my Pioneer drive !
PM sent.
Thank you very much @Coopervid
@Coopervid
It worked like a charm , even with the drive inside the OWC Mercury PRO usb enclosure , with Windows inside a Qemu VM .
Now UHD discs work .
sumboxcar182
Hello!
I'm looking to see if i can support UHD discs with my BDR-212V as well, as i think it might just need a small update, but not sure.
My makemkv info:
OS device name: G:
Revision: 1.00
Serial number: ...
Firmware date: 2020-08-07
Highest AACS version: 78
Drive platform: RS8F00
Firmware version: 1.00/ID06
My makemkv info:
OS device name: G:
Revision: 1.00
Serial number: ...
Hi guys
I just got my drive today and would like any help in getting it up and running.
I used to use ANYDVD back in the day but stopped backing up when Blu-Rays came out.
TIA
OS device name: E:
Current profile: DVD-ROM
Revision: 1.02
Serial number:
TIA
OS device name: E:
Revision: 1.02
Serial number:
JayGee68 wrote: Sun Feb 02, 2025 7:02 pm Hi guys
TIA
OS device name: E:
Revision: 1.02
Serial number:
Just email me that info see below I have a flasher for itsumboxcar182 wrote: Sun Feb 02, 2025 3:46 pm Hello!
My makemkv info:
OS device name: G:
Revision: 1.00
Serial number: ...
I just started getting into backing up Blu-ray, I have mix of regular and UHD Blu-rays. Read that the pioneer drives are the best. Also that I should get any drive with firmware before Dec 2022. So I went ahead and purchase a Pioneer BDR-212V, Verbatim 43890 (BDR-UD03), and a BDR-XD05S since all these are made before 2022. Bought a few to test out which one is better. Both the 212V and 43890 works with standard Blu-ray but not UHD, don't have the XD05 yet. I would like to enable UHD to at least one of these.
Not sure how this work but any help is greatly appreciated.
Revision: 1.00
Serial number: [removed]
Highest AACS version: 81
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.00
Revision: 1.14
christopher_2
How did you guys get this drive flashed, I bought one and am trying to figure it out SDF Tool doesn't have pioneer firmware in it.
Revision: 1.02
Serial number: ...
Highest AACS version: 12
Revision: 1.02
Serial number: ...
