You probably should contact Mike Admin as he may want to extract your drive's firmware so he can add it to the compatibility list.Ulrich wrote: Wed Jan 29, 2025 6:05 pm Hello,
I also have the drive, here is here is the data
OS device name: F:
Producer: PIONEER
Product: BD-RW BDR-X13
Revision: 1.01
Serial number: XXXXXXXXXXXXX
Firmware date: 2022-02-18
Bus encryption markings: 1B
Highest AACS version: 19
Drive platform: Pioneer RS9400
Firmware version: ID56
If I understand this correctly, LibreDrive must be enabled. How can I activate LibreDrive?
Hopefully someone can give me a hint, thanks.
Pioneer BDR-X13 Usb
Re: Pioneer BDR-X13 Usb
i dont belive this is the UHD version that would be the x13u if you email me i can flash it for you to 1.02 UHDUlrich wrote: Wed Jan 29, 2025 6:05 pm Hello,
OS device name: F:
Producer: PIONEER
Revision: 1.01
as your fw is old
@Billycar11
The following type reference is indicated on the housing BDR-X13EBK, I think it can do UHD but I'm not really sure.
Yeah just email me the drive info if it does not already see a UHD disc and I can send you a flasher for itUlrich wrote: Fri Jan 31, 2025 4:58 pm @Billycar11
I hope someone can help me with my drive as well:
OS device name: /dev/sr0
Producer: PIONEER
Product: BD-RW BDR-X13U
Revision: 1.01
Firmware date: 2022-02-28
Highest AACS version: 70
Firmware version: PIONEER BDR-213T
Firmware version: 1.01/ID29
Thx
Producer: PIONEER
Revision: 1.01
Thx
Never mind. I found the problem. Thx anyway.grobi0815 wrote: Sat May 31, 2025 4:26 pm Hello,
Producer: PIONEER
Revision: 1.01
Thx
