Harry Potter Deathly Hollows pt2
fr0z3ng33k
Post by fr0z3ng33k »
When I made my .mkv copy it was the commentary version not the movie. I wouldn't bring this up if I could just select a different movie file but the 22.3gb file is the only option which isn't even the movie. Anyone else having this issue in the US?
joe42
Re: Harry Potter Deathly Hollows pt2
Post by joe42 »
Do you mean that the audio track is commentary, but the video is the actual movie? Or is the video part also not the actual movie?
khollister
Post by khollister »
On my BD, there were two large streams - the movie was about 23 GB or so, and the one that had visual commentary was about 26 or 27 GB if I recall correctly.
vexar01
Post by vexar01 »
Trying to Backup Harry Potter and the Deathly Hallows Part 2 and getting errors. There are two large files. The first one (title01) happens to be a documentary on the video. The Second one (title02) happens to be the movie. When I try to extract the movie I am getting errors on BDMV/STREAM/00050.m2ts at offset 316059648 (see full text below). Anyone else having this issue? Thanks for any help in advance.
Systems Specs:
2011 Apple iMac 27" (Quad Core i5, 16GB RAM)
Asus External Bluray Drive
Movie Specs:
DVD Bundle purchased from Best Buy (ISBN: 0-7806-6205-9)
Log from Extract:
MakeMKV v1.6.16 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHF" opened in DASPI v1.3 mode.
Optical drive "BD-ROM ASUS SBC-06D1S-U A201" opened in DASPI v1.3 mode.
File 00200.mpls was added as title #0
Title #00008.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00220.mpls was added as title #1
File 00100.mpls was added as title #2
File 00218.mpls was added as title #3
File 00217.mpls was added as title #4
File 00216.mpls was added as title #5
File 00215.mpls was added as title #6
File 00213.mpls was added as title #7
File 00214.mpls was added as title #8
File 00212.mpls was added as title #9
Title 00211.mpls is equal to title 00220.mpls and was skipped
File 00219.mpls was added as title #10
Title #00021.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.m2ts was added as title #11
File 00018.m2ts was added as title #12
File 00117.m2ts was added as title #13
Title #00010.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #14
File 00004.m2ts was added as title #15
File 00080.m2ts was added as title #16
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00095.m2ts was added as title #17
File 00094.m2ts was added as title #18
File 00092.m2ts was added as title #19
Title #00091.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00088.m2ts was added as title #20
File 00087.m2ts was added as title #21
File 00086.m2ts was added as title #22
File 00084.m2ts was added as title #23
File 00083.m2ts was added as title #24
Title #00082.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00081.m2ts was added as title #25
File 00078.m2ts was added as title #26
File 00077.m2ts was added as title #27
File 00076.m2ts was added as title #28
File 00075.m2ts was added as title #29
File 00074.m2ts was added as title #30
Title #00073.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00072.m2ts was added as title #31
File 00070.m2ts was added as title #32
Title #00123.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00069.m2ts was added as title #33
File 00068.m2ts was added as title #34
File 00097.m2ts was added as title #35
File 00034.m2ts was added as title #36
Title #00000.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00071.m2ts was added as title #37
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00066.m2ts was added as title #38
Title #00064.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00062.m2ts was added as title #39
File 00060.m2ts was added as title #40
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #41
Title #00052.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00050.m2ts was added as title #42
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00044.m2ts was added as title #43
Title #00042.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00040.m2ts was added as title #44
File 00038.m2ts was added as title #45
Title #00036.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 97 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00030.m2ts was added as title #46
Title #00124.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00079.m2ts was added as title #47
Title #00027.m2ts has length of 97 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #48
File 00024.m2ts was added as title #49
Title #00023.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory /Users/Desktop/BD Rip
Forced subtitles track #4 turned out to be empty and was removed from output file
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '224311296'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '224317440'
Failed to save title 2 to file /Users/Desktop/BD Rip/title02.mkv
1 titles saved, 1 failed
Saving 1 titles into directory /Users/Desktop/BD Rip
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '262649856'
0 titles saved, 1 failed
The source file '/BDMV/STREAM/00050.m2ts' is corrupt or invalid at offset 312729600, attempting to work around
The source file '/BDMV/STREAM/00050.m2ts' is corrupt or invalid at offset 323284992, attempting to work around
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '381726720'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '316059648'
crowfax
Post by crowfax »
This error literally means your drive can't read the disc. There is no copy protection on blu-ray that would cause this. Most likely you have a damaged disc; least likely you have a failing drive.
squirrelman10
Post by squirrelman10 »
i was easily able to rip HP DHpt2 without error so ur disk is damaged or the driver or the reader is damaged or broken check those
squirrelman10
setarip_old
Post by setarip_old »
@fr0z3ng33k
Hi!
1) Does your original, commercial Blu-ray disc play properly on the same system (and/or standalone player)?
2) Can you use your remote (or onscreen equivalent) to exit the "Commentary" (likely under "Special Features") and play the movie?
BTW - The Title with a total of 27 chapters and 22.4GB (00100.MPLS) is the movie (It begins in pitch blackness and silence and is slow to show images, so be patient.)
The Title with a total of 40 chapters and 23.3 GB (00200.MPLS) is the visual/audio commentary.
vexar01
Post by vexar01 »
Update:
Borrowed a working external Blu-ray drive and tried again. Got the same exact error points again in the exact same file. Checked the disc surface, no blemishes or scratches. Had already watched the movie over the weekend on a PS3 and it played 100% fine. Took the disc and put it in a standard Samsung Player, popped some popcorn, and set out and watched the movie again. No errors, distortions or issues. So, went back to my original drive and extracted two more movies from Blu-ray as a test. Both came out without issue. So there is something about the encoding of this disc as far as I can see that might be causing this. I am at a loss and just slightly frustrated. Any other suggestions? Thanks for the help.
Post by mike admin »
This IS a bad (scratched) disc.
crowfax
Post by crowfax »
vexar01 wrote:Had already watched the movie over the weekend on a PS3 and it played 100% fine.
Just because it plays in your player, doesn't mean the disc is fine.
When you copy a disc it has to read bit-for-bit perfectly. When you play it, it'll skip over any errors; which you may, or in your case not, notice.
Once again, the error means your drive can't read the disc. It is damaged, return it for a new one.
fr0z3ng33k
Sorry for the delay in writing back. I re-ran MakeMKV on my Mac and I found the other file. One was 23gb the other was 22.6. The 22.6 was the one with the movie the 23 was the commentary clip.
Icetrips
Post by Icetrips »
I do both. Commentary movie and the movie, no trouble at all with the US version.
Your disk must be a bad disk.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
vexar01
Post by vexar01 »
Update:
Sorry for the delay. I understand the issue with error correction and players. I decided to try a different approach. I ran another program (pavtube) and extracted the entire Disc to a folder on the local hard drive. I then ran Handbrake directly against that folder. It produced the movie without issue and no problems detected. It is possible that there is an error in the disc itself that players are jumping over, but I think that would be improbable with other software extracting without issue. The only thing I can think of is there might be some form of software conflict occurring on the system that manifested during the rips. Either way the file has been generated and the video extracted. So far this is the only disc I have had major issues with so I am not too worried about it. Thanks for the help. Onto the next disc in the library.
setarip_old
@vexar01
Hi!
Try doing the same thing using MakeMKV instead of Pavtube. Then use the full disc backup as your source for using MakeMKV to make an .MKV...
