HI Tom dont worry you if you have them before the date posted i still honor the warranty's
and either way you still have warranty with pioneer.
there were just way to many doa Vantec's for me to deal with causing false exchanges costing you and us alot of money on shipping.
[/quote]
Billy, just wondering, do you have any experience with the Pioneer external enclosure? It looks really nice ascetically.
Just wondering if any of your BDR-X13U-X drives came with them?
Tom899 wrote: Mon Jan 27, 2025 1:41 pm
im working on 1 now actually could be a bit though before im ready to sell
its going to be alot of money probably just under $500
but i can confirm the new one does not fit pioneers with out slotting the holes or bending them i had a old one too where it barley sticks out
the new pcb in the back is bigger so drive cant slide back more
[/quote]
Is there any technical advantage to having the newer OWC enclosure (new PCB) or are they functionally the same?
Dagwood wrote: Tue Jan 28, 2025 7:06 pm
Ok, I was having a hard time with getting the sdf tool to open on my mac with no solution with this forum, and reading other areas about the issue I was having with my mac not liking that one file (My mac mini has been special not like other mac users on this forum). Well I have to say that I put my trust in Billy to provide me a solution, and he delivered. I ordered the top pioneer drive and it is worth the money. It was delayed getting to me due to the weather here in Texas and across the nation, just like the price the wait was worth it. I have been able to rip 4 movies in about 2.5 hours, one 4k, and 3 blu. So, if you need a solution, or this is your first time like mine Billy is the man to contact. Having the drive pre-flashed and having to order the housing for it was well worth it; especially when it comes to avoiding headaches and wasted hours of crazy research.
Billy, thank you Sir, your time working with me, and providing this solution is very much appreciated. Hook-Em
Thing1b wrote: Sat Feb 01, 2025 7:15 am
Not having much luck with a reply via email… so figured I’d try here.
Any UHD drive solutions for Apple? A USB-A or C?
I answered all my emails I was driving last night for about 6hr so that's why your email was not answered until now but still under 24hr is a good email response time...
I plan to use a new Blu-ray / 4K drive in my USB-C or USB-3 port, since the case cannot have it inside; In the 1st post of this thread it is suggested to buy an enclosure. Will the Vantec NexStar DX2 work with a Pioneer BDR-S13UBK or any other of the announced drives?
My old ASUS SBW-06D5H-U came with very short USB cables. One is a 2-USB + 1, there's also USB-C to 3.2 Micro-B. The latter is what I use, and had to import a 2 meter (6.5 ft?) cable, otherwise it would be IMPOSSIBLE.
Since these drives sold here for sure do not come with long cables, can you specify what type (USB-C? regular USB 3.0?) we need to buy, which I assume to be the same for ALL of them? I just read one manual from a Pioneer, and that information is absent.
EDIT: Found out it's USB 3.0, A to B, based on the Vantec case, of course. The one that comes with the DX2 it's 100 cm, so I need to get another (found today with 500 cm). And from what I saw, this enclosure should work with all internal drives.
Shermin3656 wrote: Thu Feb 27, 2025 11:00 pm
Is it possible to flash the Pioneer BDR-XD08UMB-S that I just purchased? I'm hoping that I got lucky with this one.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: ...
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
