PM sent.eek24 wrote: Sat Jan 25, 2025 1:21 pm Coopervid,
I just received my BDR-212V from Amazon this morning. I was hoping you would help me by sharing how to flash the drive to enable UHD read ability. Please note that I have never used PM so I may be blocked as a new user.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ...
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 77
Firmware version: ID06
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
jovian
Hello @Coopervid. I just got a BDR 212V as well. Can you help me flash this drive:
Revision: 1.02
Serial number:
Highest AACS version: 76
Thank you!
Revision: 1.02
Serial number:
Thank you!
eek24
Thank you Coopervid, All went well and I was impressed with the thorough documentation.
wildbomb
Thanks, all went well. UHD discs now work!
heruma
Hello @Coopervid.
I recently purchased a BDR 212V and would like to know if you could help me flash this drive when you have time?
Revision: 1.02
Serial number: ---
Thank you for your time!
Revision: 1.02
Serial number: ---
PM sent.heruma wrote: Sun Jan 26, 2025 8:40 pm Hello @Coopervid.
Revision: 1.02
Serial number: ---
heruma
Thank you very much @Coopervid for the prompt reply.
It worked wonderfully and I just finished testing the drive
traveler286
@coopervid,
I too would like instructions to upgrade my BDR 212V for 4K Ultra disk reading for Plex server. I just registered so cannot directly PM you yet.
BarryR
@Coopervid
Was wondering if you could steer me in the right direction. I have same drive as many above
OS device name: F:
Revision: 1.02
Serial number: XXX
OS device name: F:
Revision: 1.02
Serial number: XXX
victheripper
I just received a BDR 212V drive and would like to flash it for UHD support. Here is the relevant info:
OS device name: H:
Revision: 1.02
Serial number:
Highest AACS version: 18
PM sent.traveler286 wrote: Mon Jan 27, 2025 10:19 pm @coopervid,
PM sent.BarryR wrote: Mon Jan 27, 2025 11:00 pm @Coopervid
OS device name: F:
Revision: 1.02
Serial number: XXX
PM sent.victheripper wrote: Mon Jan 27, 2025 11:34 pm I just received a BDR 212V drive and would like to flash it for UHD support. Here is the relevant info:
Thanks!Code: Select all
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 18 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06 No disc inserted
BarryR
Yes, please send next PM.Coopervid wrote: Tue Jan 28, 2025 5:35 pmPM sent.BarryR wrote: Mon Jan 27, 2025 11:00 pm @Coopervid
OS device name: F:
Revision: 1.02
Serial number: XXX
PM sent.BarryR wrote: Tue Jan 28, 2025 6:09 pmYes, please send next PM.Coopervid wrote: Tue Jan 28, 2025 5:35 pmPM sent.BarryR wrote: Mon Jan 27, 2025 11:00 pm @Coopervid
OS device name: F:
Revision: 1.02
Serial number: XXX
