Any advice for ripping UHD with Orico ext drive?
RVG1963
Post by RVG1963 »
Wow! Have I ever gotten myself lost down a rabbit hole! And boy do I feel dumb. I hope I'm in the correct forum.
Trying to rip an BRD (no indication it is UHD/4K) with this drive:
ORICO External Blu-Ray DVD CD Drive, 100GB Portable 6X Ultra HD Bluray Burner for Laptop Mac MacBook PC Windows10 Support M-disc-BRGU3-01. Purchased November 2023. I'm using a MacBook Pro (2023 with M3 chip, macOS 15)
When I attempt to rip, I get this info:
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: FR07
Serial number: ...
Firmware date: 2119-05-10 13:48
Bus encryption flags: 1F
Highest AACS version: 81
Disc Information
Label: "movie_title"
Timestamp: 2022-05-21 12:21:02
Protection: AACS v76
Data capacity: 41.53 Gb
Disc type: BD-ROM
Number of layers: 2
I'm only seeing MakeMKV/LibreDrive/flashing info for Pioneer, LG, ASUS, and Verbatim...
All the "Special Features" ripped, but not the feature film. I've ripped hundreds of discs with many different region codes. Given the above info, any ideas what's going on? Thanks!
(I do not believe the disc is damaged, but...?)
Re: Any advice for ripping UHD with Orico ext drive?
RVG1963 wrote: Wed Jan 29, 2025 12:16 am Wow! Have I ever gotten myself lost down a rabbit hole! And boy do I feel dumb. I hope I'm in the correct forum.
Revision: FR07
Serial number: ...
Disc Information
Disc type: BD-ROM
Number of layers: 2
The drive inside is a LG BU40N. It should work just fine as is for DVD and standard Blu-Ray discs but would need to be flashed to enable LibreDrive and UHD compatibility.
Are you doing a complete disc to folder backup or just wanting to rip the movie to a MKV file?
You should also show us what the log window says.
RVG1963
Post by RVG1963 »
Hi, thanks for the quick response. I've just been ripping my dvd and blu-ray discs (movies and some of the extras) to MKV format so I can get rid of all my physical media. Wanna move across the country and don't want to pay to haul and store it all. I only have a few UHD/4K discs that I will keep since it seems they are more tricky to rip (although I would be interested in getting my drive flashed for the functionality, "just in case...").
So, where do I find the logs that indicate why this particular blu-ray disc will not copy. I'm trying it again right now, so I can submit the latest one shortly.
Thanks again for the assistance, Bob of Ohio.
RVG1963 wrote: Wed Jan 29, 2025 4:36 pm Hi, thanks for the quick response. I've just been ripping my dvd and blu-ray discs (movies and some of the extras) to MKV format so I can get rid of all my physical media. Wanna move across the country and don't want to pay to haul and store it all. I only have a few UHD/4K discs that I will keep since it seems they are more tricky to rip (although I would be interested in getting my drive flashed for the functionality, "just in case...").
The log is the bottom pane of MakeMKV.
RVG1963
Post by RVG1963 »
Again, thanks for the quick reply.
IT MAY BE WORTH NOTING: After I was unsuccessful in ripping my own copy of this blu-ray dvd, I borrowed an identical disc and the same thing happened - that being, I was able to rip the Special Features, but not the Main Feature. Could a "higher level" copy guard have been placed on the Main Feature by the disc manufacturer?
Anyway, after loading the disc and activating MakeMKV, this following information appeared.
MakeMKV v1.17.8 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N FR07 MODM4FG0746d" opened in OS access mode.
File 00001.mpls was added as title #0
File 00010.m2ts was added as title #1
File 00011.m2ts was added as title #2
File 00003.m2ts was added as title #3
File 00009.m2ts was added as title #4
File 00008.m2ts was added as title #5
File 00021.m2ts was added as title #6
File 00007.m2ts was added as title #7
File 00006.m2ts was added as title #8
File 00004.m2ts was added as title #9
File 00012.m2ts was added as title #10
Saving 1 titles into directory /Users/robertgibson/Desktop
Then, I only selected the main feature to rip. (As previously mentioned, I was able to successfully rip the Special Features into MKV files.)
Main Feature info:
Title information
Source file name: 00001.mpls
Duration: 1:38:11
Chapters count: 12
Segment count: 1
Segment map: 5
File name: title_t00.mkv
After MakeMKV ran for about an hour or so, this is what appeared in the dialogue box/log indicating a failure to read that particular file from the disc:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20443625472'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20443754496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20443889664'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20443951104'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20444540928'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '20444540928'
Failed to save title 0 to file /Users/robertgibson/Desktop/title_t00.mkv
Encountered 15 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
SO, I messed around in the MakeMKV preference settings (not knowing what I was doing or trying to accomplish), tried running it again and got the following error/failure messages:
Saving 1 titles into directory /Users/robertgibson/Desktop using profile 'AAC-stereo' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/appdata.tar:aac-st.mmcp.xml'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20450439168'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '20460662784'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '23537909760'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '23537971200'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '23537971200'
DEBUG: Code 1073741829 at q3An)$5vw:?Ba+v4.5:213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '23538106368'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '23538106368'
DEBUG: Code 100864261 at q3An)$5vw:?Ba+v4.5:213131502
DEBUG: Code 0 at A~M`+mtEfMU$dSR;GYX_:29395793
DEBUG: Code 0 at DS`X@h)l"T|5!}6|+EJ<:29394068
DEBUG: Code 0 at A~M`+mtEfMU$dSR;GYX_:213131157
DEBUG: Code 0 at A~M`+mtEfMU$dSR;GYX_:121262647
DEBUG: Code 11493216 at A~M`+mtEfMU$dSR;GYX_:121261773
DEBUG: Code 0 at xxTW#V:nz;CL=B^ipzC#=:121268972
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Encountered 25 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
The "makemkv.com/errors/read" link states that it can only be a damaged disc or a failing drive, but disc does play in a Panasonic UHD 4K blu-ray/dvd/cd player and my Orico ext drive still seems to be working fine.
Therefore, I'm completely stumped and out of my league.
What thinks you?
Thanks, Bob of Ohio
RVG1963 wrote: Thu Jan 30, 2025 1:11 am Again, thanks for the quick reply.
Main Feature info:
Title information
Duration: 1:38:11
Chapters count: 12
Segment count: 1
Segment map: 5
What thinks you?
Thanks, Bob of Ohio
Playing is totally different to reading. Apples to Oranges.
When ripping, the data must be read successfully bit by bit exact. Players will simply buffer and skip over any data errors. You may or may not notice any sort of quick glitch when watching it. Anyway, obviously the drive is having a hard time reading a section of the disc causing it to fail. Probably a scratch or dust or something. You could try giving it a good clean and see if that helps.
zittrig
Post by zittrig »
I looking forward a Orico drive. Amazon Germany has a special offer from Orico with 50 % discount. I'm curious how the BU40N works with the Orico enclosure.
zittrig
Post by zittrig »
Arrived and tested. The BU40N in the Archgon, Techpulse and Buffalo enclosures are better processed and more valuable imo, but it does what it's supposed to do.
zittrig
Post by zittrig »
I've another Orico here. The same from Amazon Germany. This time it contains a BU50N.
zittrig wrote: Mon Feb 10, 2025 4:38 pm I've another Orico here. The same from Amazon Germany. This time it contains a BU50N.
Same thing as bu40n haven't seen one of those for a while I think it's the hp rebrand of the bu40n
zittrig
Post by zittrig »
This could be, I couldn't find specific differences between this two drives. E.g. on ebay you can find the BU50N with or without HP branding, same with the BU40N.
But downgrade to BU50N 1.00 works and the drive runs with MakeMKV and DVDFab.
zittrig
Post by zittrig »
A warning for the Orico: A friend of mine bought one also on Amazon.de and .... we found a Matshita drive inside as he came for flashing. :!:
So there could be inside these drives possible as far as is known:
- LG BU40N (flashable)
- LG BU50N (flashable)
- Matshita BD-MLT UJ272 (not flashable)
