Stargate SG 1 Season 3 Disc 1 und 2
fairyknight
#1 Post by fairyknight » Sun Jul 11, 2021 10:43 am
Hi
I have been ripping my DVDs to store them on my NAS and I have run into a problem anbd wanted to hear if anybody has the same Problem. I collected the silver Edition of the Stargate Series and unfortunately the glue used in making the boxes has damaged the disc. There was a smear on most of them. I could clean the discs but Disc 1 and 2 of Season 3 weren´t read by MKV. I then ordered a used copy of Season 3 (to get the missing episodes) in the non silver edition. I found it seemed to be the same discs but in better condition but they too had the same mistake. Then I borrowed another version of Season three from a friend (Unopened!! The truth) and those 2 disc still can´t be ripped. I am now sure it is not the physical disc but the files. I even tried copying to harddrive - no problem while copying but unable to rip these episodes. Any Ideas what I can still try?
I am a total noob but had no major problems sofar.
Re: Stargate SG 1 Season 3 Disc 1 und 2
#2 Post by dcoke22 » Sun Jul 11, 2021 7:10 pm
If it is a smear of glue that is making the discs unreadable, you can try cleaning them a 2nd, 3rd & 4th time.
What logs does MakeMKV give when trying to read the discs?
fairyknight
#3 Post by fairyknight » Mon Jul 12, 2021 5:59 am
I don't think its is the glue since the other discs have the same problem:
This is the error when opening the discs
MakeMKV v1.16.4 win(x64-release) gestartet
Öffne Dateien auf Festplatte in G:/MKV/serien/Stargate/s3/D1/VIDEO_TS
Berechneter BUP-Offset für VTS #0 stimmt nicht mit dem im IFO Header überein
Berechneter BUP-Offset für VTS #1 stimmt nicht mit dem im IFO Header überein
Titleset-Startsektor falsch zugeordnet für Titleset 1 : 106 != 105
Berechneter BUP-Offset für VTS #2 stimmt nicht mit dem im IFO Header überein
Titleset-Startsektor falsch zugeordnet für Titleset 2 : 1171645 != 1171644
Berechneter BUP-Offset für VTS #3 stimmt nicht mit dem im IFO Header überein
Titleset-Startsektor falsch zugeordnet für Titleset 3 : 2046200 != 2046199
Berechneter BUP-Offset für VTS #4 stimmt nicht mit dem im IFO Header überein
Titleset-Startsektor falsch zugeordnet für Titleset 4 : 2924987 != 2924986
Berechneter BUP-Offset für VTS #5 stimmt nicht mit dem im IFO Header überein
Titleset-Startsektor falsch zugeordnet für Titleset 5 : 3798744 != 3798743
Berechneter BUP-Offset für VTS #6 stimmt nicht mit dem im IFO Header überein
Titleset-Startsektor falsch zugeordnet für Titleset 6 : 3926633 != 3926632
Titel #1 wurde hinzugefügt (4 cell(s), 0:42:22)
Titel #2 wurde hinzugefügt (4 cell(s), 0:42:24)
Titel #3 wurde hinzugefügt (4 cell(s), 0:42:23)
Titel #4 wurde hinzugefügt (4 cell(s), 0:42:24)
Titel #5 wurde hinzugefügt (1 cell(s), 0:07:01)
Titel #6 wurde hinzugefügt (1 cell(s), 0:03:16)
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 12288. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 18432. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 73728-77824. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 83968. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 83968-86016. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 86016. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 90112. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 129024. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 169984. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 196608-198656. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 198656. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 204800. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 204800-206848. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 206848-208896. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 208896. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 215040. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 215040-217088. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 217088. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 223232. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 223232-225280. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 231424. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 231424-233472. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 233472. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 239616. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 239616-241664. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 385024. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 430080-432128. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 432128. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 438272. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 438272-440320. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 440320-442368. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 442368. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 448512. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 448512-450560. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 450560. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 450560-452608. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 452608. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 458752. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 464896. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 487424. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 528384. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 569344. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 608256. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 649216. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 909312. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 950272. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 991232. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1017856. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1021952. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1069056. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1110016. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1150976. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1189888. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1271808. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 16384. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 32768. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 73728. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 81920. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 94208. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 174080. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 212992. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 221184. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 229376. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 237568. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 268288. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 389120. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 430080. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 436224. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 446464. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 456704. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 462848. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 532480. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 612352. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 954368. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1026048. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1073152. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1155072. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1275904. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1355776. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 1476608. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 172032. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 200704. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 210944. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 266240. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 387072. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 434176. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 444416. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 454656. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 460800. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 610304. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 720896. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 872448. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_01_1.VOB' ist defekt oder ungültig bei Offset 952320. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 12288. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 18432. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 73728-77824. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 83968. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 83968-86016. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 86016. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 90112. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 129024. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 169984. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 196608-198656. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 198656. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 204800. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 204800-206848. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 206848-208896. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 208896. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 215040. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 215040-217088. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 217088. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 223232. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 223232-225280. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 231424. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 231424-233472. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 233472. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 239616. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 239616-241664. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 385024. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 413696-415744. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 415744. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 421888. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 421888-423936. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 423936-425984. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 425984. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 432128. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 432128-434176. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 434176. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 434176-436224. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 436224. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 442368. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 448512. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 471040. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 512000. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 552960. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 591872. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 632832. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 774144. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 856064. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 894976. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 935936. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 1056768. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 1097728. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 1138688. Es wird versucht, dies zu umgehen
Die Quell-Datei 'G:/MKV/serien/Stargate/s3/D1/VIDEO_TS/VTS_02_1.VOB' ist defekt oder ungültig bei Offset 1177600. Es wird versucht, dies zu umgehen
Die Aufgabe wurde erfolgreich abgeschlossen
#4 Post by dcoke22 » Mon Jul 12, 2021 1:53 pm
The log reminds me of this thread: viewtopic.php?f=7&t=25227
Unfortunately, I don't think that thread provides an answer. Is there a different optical drive you can try?
fairyknight
#5 Post by fairyknight » Mon Jul 12, 2021 5:48 pm
I tried in 1 Dvd and 2 bluray drives, all had this problem, I tried in my PS4 it plays the dvd without problem. When I use vlc it can‘t play the files proper
rblood01
#6 Post by rblood01 » Fri Jul 23, 2021 9:51 pm
Just to cover the basics, this is a dvd from your region? correct? If so it might just be the disk IMO as multiple devices not working it is hard for me to believe it is something to do with the devices. I happen to have the complete Stargate collection and haven't had any issue with ripping. (however, the original rips were to ISO using Anydvd and then rips from that to MPK video file using Make MKV ... the ISO rips / copies were so I had a backup. )
fairyknight
#7 Post by fairyknight » Wed Sep 01, 2021 2:34 pm
Yes, they are from my region, and it is just those two discs from all Seasons and with 3 differrent Versions of the 3rd Season. Just out of curiosity: Are you europe based? Perhaps there is a problem with the v Region version.
Thanks Fairyknight
Michael A.
#8 Post by Michael A. » Tue Jan 28, 2025 6:16 pm
i know i am late to the Party, but i ran into the same Problem with the silver Stargate Boxset. Yes the smear seams to be glue or some solvent from the glue. Water an Soap did not help.
But CD's / DVD / Blu Rays are made of polycarbonate witch has no Problem with isopropyl alcohol. Use a microfiber cloth and 99% isopropyl to clean the Discs (only on the reflective Side!).
I am ripping Season 4 at the Moment, 1,2,3 and 5 already done.
I had only one Disc (S5D3) that seams damaged beyond repair, since the Coverprint is partially visibly on the reflective Side.
Hope this helps!
Regards
Michael
