Speed control
Pcbd78
Speed control
Post by Pcbd78 »
Cant get speed control to work. I set the registry values on my bd-drives. Does it only work when ripping? I would like to use it when playing discs. Windows 7 and the latest makemkv.
Re: Speed control
As far as I'm aware, it only works for ripping. Out of curiosity, why would you want to use it when playing a disc?
Pcbd78
Re: Speed control
Post by Pcbd78 »
So that drive isnt that noisy while playing discs. Theres ofcourse 3rd party speed limit apps but they wont work on my Pioneer BDR-209EBK. Drive has its own quiet mode but i read it slows down the drive to 2x. So slow speed is more prone to defected sectors on the discs. 8x would be slow enough.
Re: Speed control
You could always just rip the disc and playback the file.
Ari2010
Re: Speed control
Post by Ari2010 »
Pcbd78 wrote: Sun Jan 26, 2025 6:11 pm Cant get speed control to work. I set the registry values on my bd-drives. Does it only work when ripping? I would like to use it when playing discs. Windows 7 and the latest makemkv.
Speed control usually only kicks in when ripping, not during playback. Blu-ray drives tend to auto-adjust speed when playing. You might need third-party software to force it. What drive are you using?
