if the trim is not static, remove cmv4.0darrrkmanxxx wrote: ↑Thu Jan 23, 2025 12:12 pmCMV2.9 and CMV4.0? Only one l2 trim.
Should I go for cm_analyze in such case?
All the older MA webdl has this weird 2-frames cmv4.0 data.
RESET_9999 wrote: ↑Thu Jan 23, 2025 12:27 pmHi re:clipping fix on cpm build, what is it meant to look like after it's fixed?
I want to test it on my lg-c6 but something tells me it probably won't make a difference on this tv.https://github.com/cpm-code/xbmc/discussions/47
Thanks.
Yes, it will make a difference because this build allows Level 5 and positive lift to work with TV-LED.Donpoku wrote: ↑Sun Jan 26, 2025 8:22 amHi re:clipping fix on cpm build, what is it meant to look like after it's fixed?
Thanks.
So, just to make sure I understand and am coming to the correct conclusions:RESET_9999 wrote: ↑Thu Jan 23, 2025 1:16 amThe best is to use an MDL based on the measurement from 6-2 but the mediainfo metadata is ok.
Wow, that's very interesting and great news!RESET_9999 wrote: ↑Sun Jan 26, 2025 4:48 pmActually, that clipping behavior with content brighter than the RPU MDL just got patched in cpm's coreelec build so if you use one of the CE devices, you can now do my initial suggestion of using 1000nits MDL if 10% or less is over 1000nits. Either way, 1000nits is the correct selection for that Seinfeld episode plot but I've seen other episode's plots that spiked to 10 000nits..
If your player is the x800m2/x700 or oppo, then you should respect the mediainfo MDL if there's a shot over the RPU MDL. These 3 players (probably all the bluray players) are altering the RPU that is being sent to the TV. They limit the L1 metadata to the RPU MDL causing the clipping when the content is brighter. In other words, the rpu response differences we noticed years ago between devices are finally explained.
The new CE update removed that limitation so now it sends original metadata to the display and processes the metadata identically to the TV internal player(or the shield and appleTV).
If the content is graded within the MDL, then all of this is pretty much meaningless but there's one even better thing that this update brought. It has enabled the Level 5 metadata and the positive offset lift that never worked on any HDMI device so far. Positive Lift metadata are frequently used in most movies. So this update brought an already great device to perfection levels.
Can you do screen comparisons of before & after fix. I've tested it on ce-nightlies & new test build by cpm build(with this autostart.sh-echo Y > /sys/module/amdolby_vision/parameters/dolby_vision_keep_source_meta_level_5)RESET_9999 wrote: ↑Sun Jan 26, 2025 1:11 pmYes, it will make a difference because this build allows Level 5 and positive lift to work with TV-LED.Donpoku wrote: ↑Sun Jan 26, 2025 8:22 amHi re:clipping fix on cpm build, what is it meant to look like after it's fixed?
Thanks.
As for the clipping fix, try this file and see if there's a difference. It most likely has a big difference, the old CE builds (and oppo/x700/x800m2) are altering the RPU, they limit the metatada to the RPU source_pq(MDL)
https://drive.google.com/file/d/1Oparjy ... sp=sharing
<Shot>
<UniqueID>9a4c3aa0-9f65-44fa-b8cb-5929e40ba466</UniqueID>
<Record>
<In>86400</In>
<Duration>1166</Duration>
</Record>
