BDR-XD08EMB-S
andser
BDR-XD08EMB-S
Post by andser »
As every other newbie stumbled upon what is needed.
OS device name: /dev/sr1
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: ...
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
Disc Information
Disc is being loaded
Debug log shows only this:
Debug log started at Sun Jan 26 06:59:28 2025 , written by MakeMKV v1.17.8 linux(x64-release)
001005:0000 MakeMKV v1.17.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///~./MakeMKV_log.txt
Network access is ENABLED, CURL version 8.5.0/OpenSSL/3.0.13/1.59.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at }jexA76La`JjTu9fehtZ;%:29393631
No  SDF v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
SDF id v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
SDF auto v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
Tried with few Blu-ray, UHD which a standard player reads with no issues. The BDR-XD08EMB-S keeps endlessly spinning.
Troubleshooting Steps Taken:
  • Verified disk and drive detection on Linux.
  • Checked for firmware updates or patches - this is where I am not clear what else is needed.
  • Ensured proper permissions for /dev/sr1.
  • Tested with multiple Blu-ray discs to rule out disk-specific issues.
  • Enabled debug logging in MakeMKV.
  • Reviewed relevant posts on MakeMKV forums but have not found a resolution.
Request for Assistance:
  • Recommendations for resolving the issue with the current PIONEER BD-RW BDR-XD08EMB-S drive.
  • Firmware or configuration adjustments to enable LibreDrive and successful ripping of 4K UHD Blu-rays.
Thank you in advance for your time and expertise.
Re: BDR-XD08EMB-S
andser wrote: Sun Jan 26, 2025 7:09 am
I think your firmware is too new to support LibreDrive. Consequently this drive won't be able to rip UHDs.
Re: BDR-XD08EMB-S
andser wrote: Sun Jan 26, 2025 7:09 am As every other newbie stumbled upon what is needed.
Revision: 1.02
Serial number: ...
Disc Information
It is fine for BD but can't be made libredrive or UHD comaptible as firmware is post 11/2022. Return it if you can.
