DVD Opening Modes with homemade DVD
nothingworks
#1 Post by nothingworks » Sun Jan 26, 2025 4:04 am
I’m trying to convert a homemade DVD with no copy protection. I’ve converted a ton of them from the same creator, same machine, etc. On the first attempt to read the disc, Title 4 was skipped because it was declared to be a fake title.
I understand that Structure Protection is only for commercial DVDs, but after reading the description of each mode, it seemed like CellFull might give me better results. Title 4 still didn’t open, but the “real length” changed, which makes me think the Structure Protection was doing something.
I’ve posted the log from both attempts. I will certainly clean the disc and try again (I’m skeptical that will change anything), but it would help to have a better understanding of the practical effects of the different Structure Protection modes and to what degree they impact homemade DVDs, if at all.
Thanks.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-X13 1.03 CHDL000164UC' at offset '246501376'
Title #1 was added (56 cell(s), 0:59:07)
Title #2 was added (69 cell(s), 1:13:04)
Title #3 was added (52 cell(s), 0:54:47)
Cells 47-49 were removed from title end
Title #4 declared length is 0:48:54 while its real length is 0:12:37 - assuming fake title
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-X13 1.03 CHDL000164UC' at offset '151629824'
Title #4 declared length is 0:48:54 while its real length is 0:08:30 - assuming fake title
