Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
Deleted. Responded already to another post.
IShopper42
Post by IShopper42 »
Hi Billycar11,
Billycar11 wrote: Mon Dec 16, 2024 3:47 pm
IShopper42 wrote: Mon Dec 16, 2024 3:40 pm Hi Billycar11,
I ordered a BDR-212V from Vinpower Digital's Australian office. The drive I was shipped is labeled as a DBR-212BK. I was told to test the drive to see if it is UHD enabled. This is what I get from MakeMKV:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: (Redacted)
Firmware date: 2022-12-20
Firmware version: ID81
Is this drive unlockable?
Regards,
Ian.
No return it I still have the newest gen pioneers with old fw if you want one see below
I took a gamble and purchased a BDR-212DBK from an Amazon sale. The drive was manufactured in October 2024 but appears to have older firmware:
OS device name: E:
Product: BD-RW BDR-212D
Revision: 1.02
Firmware date: 2022-03-16
Bus encryption flags: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
Have I lucked out with an unlockable drive this time? If so, can you help me out with the appropriate firmware and instructions?
Regards,
Ian.
andser
Post by andser »
After reading recommendations I landed with:
OS device name: /dev/sr1
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CIDL001355WL
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
In the debug logs:
No  SDF v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
SDF id v098: PIONEER_BD-RW__BDR-XD08U_1.02_CIDL001355WL
Your help is greatly appreciated.
BTW: Tried to create a new post, however as a newbie to this forum either was not successful or blocked by moderations filters.
IShopper42 wrote: Sun Jan 26, 2025 11:37 am Hi Billycar11,
Regards,
Ian.
OS device name: E:
Revision: 1.02
Regards,
Ian.
yeah you are in luck email me that info below
IShopper42
Hi Billycar11,
Billycar11 wrote: Sun Jan 26, 2025 1:46 pm yeah you are in luck email me that info below
Email message sent.
Thank you.
Regards,
Ian.
andser wrote: Sun Jan 26, 2025 12:50 pm After reading recommendations I landed with:
Revision: 1.02
In the debug logs:
This drive is incompatible. It has the post 11/2022 firmware and cannot be flashed at all. Return it if you can.
smaxsomeass
Post by smaxsomeass »
is this drive good to flash for uhd use? may i have the instructions please?
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ...
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
smaxsomeass wrote: Sat Feb 01, 2025 8:34 pm is this drive good to flash for uhd use? may i have the instructions please?
Revision: 1.02
Serial number: ...
PM sent.
smaxsomeass
Coopervid wrote: Sat Feb 01, 2025 10:00 pm
Revision: 1.02
Serial number: ...
PM sent.
Yes, please send next PM
smaxsomeass wrote: Sat Feb 01, 2025 11:19 pm
Revision: 1.02
Serial number: ...
PM sent.
PM sent.
smaxsomeass
Coopervid wrote: Sun Feb 02, 2025 12:37 am
PM sent.
PM sent.
worked like a charm, thanks coopervid
indigo9
Post by indigo9 »
I have a Pioneer BDR-212V that is coming from Runtechmedia. Fingers crossed that it doesn't come with a newer firmware after 2022. Will report back.
indigo9
Post by indigo9 »
Reporting back that my order arrived and did not have a firmware after 2022.
@Coopervid, can you please help me to enable UHD ripping on this pioneer model? Thanks in advance.
Here is the info I got from MakeMKV:
Revision: 1.02
Serial number: XXXXX
Highest AACS version: 77
vmware-fanboy
Post by vmware-fanboy »
Coopervid wrote: Fri Jan 17, 2025 11:25 am
vmware-fanboy wrote: Thu Jan 16, 2025 4:12 pm Hello Coopervid I have just purchased Pioneer BDR-212V with drive information below.
OS device name: E:
Revision: 1.02
Highest AACS version: 68
Can you please advise me on next steps for libredrive firmware?
Thank you very much.
PM sent.
Thank you - worked.
ImDeranged
Post by ImDeranged »
I just replaced my LG drive with one of the BD-RW BDR-212V from Amazon. Info is. It's already done a disc two other drives couldn't read.
"Drive Information
Current profile: DVD-ROM
Revision: 1.02
Serial number: ...
Firmware version: ID06"
I'd also like info on unlocking UHD. Thank you in advance.
