Asus BW-16D1HT : Stuck in Boot Mode
Psyire
Post by Psyire »
I followed this youtube video: https://www.youtube.com/watch?v=jyQV1aPlbow&t=222s
Flashed my Asus BW-16D1HT to 3.10, it said 100% Finished and just stayed there. (never moved on to "Done Successfully") So I'm assuming it didnt' go 100% according to plan.
I did not use "enc" because it was not listed as an encrypted firmware from what I could tell.
Now the drive just says "Boot" in MakeMKV and the light continually flashes, drive won't open or close.
Anyway I can re-flash or reset somehow?
Psyire
Re: Asus BW-16D1HT : Stuck in Boot Mode
Post by Psyire »
Well.. I figured out the issue. The drive was manufactured in 2013. Doh! It was purchased second hand from a guy who said he bought it in 2019. I guess I shouldn't have taken his word for it and looked at the date on the drive. (it was in a computer case that I bought)
Any way to covert this back to original or is it borked for good?
zittrig
Post by zittrig »
Sounds to me that you flashed a MT-1939 drive. Old technical platform. I think it's electronic waste.
You can try it with the DOS flash solution but this is no fun and needs some older technical requirements..... described here..... viewtopic.php?f=16&t=19634
Psyire
Post by Psyire »
Thanks for the inf zittrig. Unfortunately I can't find any DOS flashing info in the link you provided.
Has anyone brought one of these older Asus drives out of boot mode before?
It is down near the bottom in a section titled "only use the recovery steps for older NS40 drives!!:"
There's a link to a video in there too.
It is probably also important to know an Asus BW-16D1HT drive is really an LG drive on the inside. Asus doesn't make their own drives; they're rebadged LG drives.
Psyire
Post by Psyire »
Thank you! I didn't know it was an NS40 drive...
Psyire
Post by Psyire »
Alright, well I was able to recover the drive by booting into WinPE and using Dosflash to restore WH16NS60 1.01 firmware via the guide/youtube vid.
The drive now functions properly and reads standard Blurays/DVDs. (Woot!)
Next question: Is it possible to flash to a UHD compatible firmware with a 2013 NS40 based Asus drive? The guide linked above states 2015 and newer so I'm thinking no?
Psyire wrote: Sun Feb 23, 2025 10:54 pm Alright, well I was able to recover the drive by booting into WinPE and using Dosflash to restore WH16NS60 1.01 firmware via the guide/youtube vid.
No can't do UHD at all
zittrig
Post by zittrig »
I've an ASUS BW-16D1HT, buyed as defective for no money.
Laufwerksinformation
OS-Gerätename: F:
Produzent: ASUS
Produkt: BW-16D1HT
Revision: BOOT
Highest AACS version: 82
Keine Disk eingelegt
Mfc Oct. 2019, looks like it's no fake with the enclosure and stickers. I think, the former user has flashed wrong.
No LED working, tray can't be opened.
I tryed to flash with SDFtool (declares it's no MT-1959) and the modified ASUS flasher, without success.
Any ideas?
zittrig wrote: Sun Jul 05, 2026 12:29 pm I've an ASUS BW-16D1HT, buyed as defective for no money.
OS-Gerätename: F:
Produzent: ASUS
Produkt: BW-16D1HT
Revision: BOOT
Any ideas?
try the lg unlocked flasher in my de pack
zittrig
Post by zittrig »
Billycar11 wrote: Sun Jul 05, 2026 12:33 pm
OS-Gerätename: F:
Produzent: ASUS
Produkt: BW-16D1HT
Revision: BOOT
Any ideas?
I've tryed but with error "Write DRAM NG 05/26/03".
what fw are you flashing?
zittrig
Post by zittrig »
Billycar11 wrote: Sun Jul 05, 2026 12:50 pm what fw are you flashing?
AAH, sorry, Billy, I tryed mindless the 3.02 from the pack. But with the 3.10MK the flash was succesfull and the drive now works absolute fine.
Thank you :!: :!:
