http://en.wikipedia.org/wiki/Ripping
"Ripping is the process of copying audio or video content to a hard disk, typically from removable media.
The word is used to refer to all forms of media.
[Despite the name, neither the media nor the data is damaged after extraction.]"
To quote from:
http://en.wikipedia.org/wiki/Transcode
"Transcoding is the direct digital-to-digital data conversion of one encoding to another,[1]
such as for movie data files or audio files."
See:
http://en.wikipedia.org/wiki/DVD_ripper
[This is EXACTLY what MakeMKV is!]
Based on these definitions, I'm hoping we can all come to agreement, that 'MakeMKV' is
NOT a transcoding tool.
My reading of all this boils down the word 'transcode'
to mean, literally, to CHANGE codecs. ('trans' == change' and 'code' == codecs or encodings.
Wikipedia elsewhere discusses both .mkv and .mp4 file-extensions, and (correctly in my view)
refers to them as 'container-formats'. http://en.wikipedia.org/wiki/Container_format_(digital)
I mention all this here, because when I read how your product describes itself on
the base-page on the Internet, it totally MIS-states it! To quote from:
http://www.makemkv.com/
MakeMKV is your one-click solution to convert video that you own into free and
patents-unencumbered format that can be played everywhere.
MakeMKV is a format converter, otherwise called "transcoder".
I'd argue that rather than calling it a 'format converter', a better description would be to
call it a 'container-format converter'. And, that you DEFINITELY need to REMOVE
the phrase '...otherwise called "transcoder" '.
Because it is NOT a transcoder.
(Whether you should instead add the term 'ripper', is your call. According to the
strict defn, I guess makeMKV IS a 'ripping tool'. But, I'll let you decide about that point.)
Also, in another thread, we already discussed and concluded that 'makeMKV' is NOT
a compression-tool. Maybe something about that issue, should also get mentioned
in that product-description paragraph!?
[As an aside: another nice product, named 'HandBrake' is just the opposite of 'MakeMKV'.
HandBrake really IS a transcoder, and is designed to convert the video/audio sub-streams from
one codec type to another. That type of conversion takes MUCH more time and processing-power,
than doing what 'makeMKV' does. One of HandBrake's other nice features, is that it allows one to choose
whether to create the output-file as either a 'MP4' container or as a 'MKV' container.]
This is what I love about 'makeMKV'!
change codec encodings, it can neatly and quickly extract the video and audio data
into a series of of 'mkv-containers'.
Nice job. Nice product!
Bottom line, I think your product description needs to be re-written. Someone with a bit
more technical understanding needs to carefully add terms such 'codec' and 'container-format',
to get the product description more in line with proper terminology.
[But, that's just my opinion.]
Thanks for listening. Hope this is helpful...
