Pop Up Error Message on Install
Maxxnme11691
Post by Maxxnme11691 »
Hi! I downloaded this app to my PC yesterday for the first time and was able to prepare a vid file on a DVD. Hurray! I attempted to work with another DVD today and this is what I get )see screenshot). I've uninstalled, changed directories...not sure where to go to fix! Thanks much!
Re: Pop Up Error Message on Install
Beta keys included in the download expire at the end of odd-numbered months. And if the program hasn't changed in a few months, they key in the zip file can be expired before you start.
You need to get the current beta key to run the program if you don't have a permanent key. There is a topic here that always has the most recent beta key.
Maxxnme11691
Thank you...that worked!
