LG WH16NS60 and Firmware Questions
fatallysilent
Post by fatallysilent » Fri Jan 24, 2025 11:28 pm
Hello all,
I have been recently been wanting to get back into the UHD backup hobby. I have a LG WH16NS60 that I guess (according to MakeMKV) I patched a while back to 1.01.
Two questions if someone would be so kind to help:
1) What is the difference between 1.02 MK and non-MK bin files? Do the MK firmwares patch the drives and enabled the drive to be a LibreDrive? (in search for an updated flash here, I found both MK/non-MK).
2) Is there any reason to upgrade to 1.02? Or better yet, 1.03? I found 1.03 in another thread with firmwares [0].
Any help would be greatly appreciated,
FaTaL
0: viewtopic.php?f=19&t=19113
0: "mk-firmware-pack-20200720\MK\HL-DT-ST\WH16NS60\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin"
Re: LG WH16NS60 and Firmware Questions
Post by MartyMcNuts » Sat Jan 25, 2025 1:22 am
fatallysilent wrote: Fri Jan 24, 2025 11:28 pm Hello all,
FaTaL
The drive should be fine as is. No need to change the firmware. If you really want to, 1.02-MK is recommended. 1.03 is not.
There are some non MK firmware files, such as WH16NS60 1.00 which are libredrive enabled already and also allow the drive to be used with other ripping software (whereas MK firmware really only works with MakeMKV). MK firmware enables libredrive.
fatallysilent
Post by fatallysilent » Sat Jan 25, 2025 3:30 am
MartyMcNuts wrote: Sat Jan 25, 2025 1:22 am
FaTaL
Cool, sounds like I'll be following my software development creed on this then:
"If it's not causing problems, it's not worth touching."
I appreciate your quick response and information regarding MK vs. Non-MK firmware.
FaTaL
