Se7en Dump File Submitted
Re: Se7en Dump File Submitted
TORRRRR wrote: Fri Jan 24, 2025 11:33 pm Quick question - I see the full 4K feature as an "800" file, and another as an "801" file. Are they both good? One real one fake? The 800 file is 73.66GB and the 810 file is 73.48GB.
Do they both have the same segment map? Maybe there's different audio tracks in each?
TORRRRR
Post by TORRRRR »
Same Segment Map of 79 each. Identical duration: 2:06:54
Toad King
Post by Toad King »
The 801 playlist is specifically for Japan. (Only has English and Japanese audio and subtitle tracks.) 800 is for all other countries. (Contains all non-Japanese tracks.) This is a common pattern for WB releases. Pick which ever one has the tracks you want.
JoshS
Post by JoshS »
SamuriHL wrote: Sun Jan 05, 2025 4:10 pm
erizock wrote: Sun Jan 05, 2025 3:07 pm Sorry for the noob question but if the volume key is now in KeyDB and I have “enable internet access” checked on my MakeMKV, do you guys know why i still can’t decode/rip my Se7en UHD?
Because those two things are not the same. They KeyDB is a public database of keys not associated with MakeMKV. MakeMKV, however, can use it if it's extracted to the proper folder. MakeMKV maintains its own private key database commonly called the hashed keys that the enable internet access checkbox allows it to update. It sounds like the key is in the KeyDB public database however has not yet been added to the MakeMKV internal hashed keys yet. If you want to decrypt this title now, you can download the KeyDB zip file and extract it to the folder where MakeMKV puts the TGZ dump files, commonly c:\users\<usernamehere>\.MakeMKV on windows.
So I've only ripped a few 4k Blurays and I've had an issue with this title. I have downloaded the KeyDB.cfg file and extracted it in my .makeMKV folder like you said and I'm still getting the same error. It says the key isn't present and I downloaded a file from 3/3/2025. What am I doing wrong. Also its a Libredirve enabled.
Post by SamuriHL »
Easiest thing to do is to post a link to the tgz dump file and someone may be able to take a look at it and help.
lfoust
Post by lfoust »
I was able to successfully rip my copy. Here is how it layed out: https://thediscdb.com/movie/se7en-1995/releases/2025-4k
